UDF for a SEMIcircular inlet cross section (3D simulation) |
January 2, 2022, 08:49 |
Alex
Rep Power: 5 |
I everyone,
currently I'm trying to solve numerically the multiphase flow in a semi-cylinder (the problem is symmetrical with respect to a given plane passing through the center of the cylinder; on that plane a symmetry b.c. has been imposed). What I want to impose is a fully-developed flow as boundary inlet condition; the expression for the velocity profile, if the problem was 2D-axisymmetric, would be the following: u(r)=-10.1424*r^3+0.0516*r^2-0.0197*r+0.087 does has anyone idea about how to write the UDF? Thanks in advance, Kerouac |
January 3, 2022, 02:25 |
Rep Power: 5 |
Did you try using Fluent's expressions? If I remember correctly, you can define radius as (x**2+y**2) and write your expression directly into Fluent's GUI without ever needing to compile a UDF for it.
January 4, 2022, 09:35 |
Rep Power: 27 |
It's a DEFINE_PROFILE condition. The manual has an example.
My hint would be to start with that example, and change the equation to yours. If this is giving you problems, please be more specific on which step is giving you problems.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
January 6, 2022, 06:37 |
Alex
Rep Power: 5 |
I solved the problemby myself.
The idea is that to write a normal udf for velocity inlet, as it was a complete circular cross section in 3D domain. The symmetry does not have influence on the profile, because the inlet flow field is simply symmetrized. I will post the complete udf, for those which have a similar problem: #include "udf.h" #include "math.h" DEFINE_PROFILE(inlet_y_velocity, thread, index) { real y[ND_ND]; /* this will hold the position vector */ real x; real z; real a; face_t f; begin_f_loop(f, thread) /*loops over all faces in the thread passed in the DEFINE macro argument*/ { F_CENTROID(y,f,thread); x =y[1]; z =y[1]; a = pow((pow(x,2)+pow(z,2)),0.5); F_PROFILE(f, thread, index) = -10.142387415545718*a*a*a+0.051610679345377*a*a-0.019652442143266*a+0.087031654863898; } end_f_loop(f, thread) } Best regards, Kerouac |
udf and programming, velocity udf |
static Pressure profile using udf at velocity inlet | vivek123 | Fluent UDF and Scheme Programming | 0 | September 22, 2021 15:44 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
UDF to avoid shock at wind tunnel inlet | Goel | FLUENT | 0 | June 20, 2021 18:24 |
UDF problem- time dependent temperature at inlet | kaeran | FLUENT | 1 | June 16, 2015 22:48 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
