UDF-Divergence detected in AMG solver: bin-0-fraction
Old   December 18, 2021, 15:56
Question UDF-Divergence detected in AMG solver: bin-0-fraction
Amin
maba is on a distinguished road
Hi to all.
I am simulating separation of water from oil by population balance method. The simulation works well, when I use default aggregation model(luo-model) or even user defined aggregation model introduced by documentation. But when I use my user defined function(It compiled without error), at first time step without any iteration, it gives the error
"Divergence detected in AMG solver: bin-0-fraction
Error at host: floating point exception
Error at Node 0: floating point exception
Error: floating point exception
Error Object: #f "
What is the source of this error?
The user defined function is as follows:
UDF that computes the particle aggregation rate
#include "udf.h"
#include "sg_pb.h"
#include "sg_mphase.h"
DEFINE_PB_COALESCENCE_RATE(aggregation_kernel,cell ,thread,d_1,thread_2,d_2)
real agg_kernel, mu, delta, e_ij, V_ij;
real rho_o=850, rho_w=1000, mu_o=0.013, mu_w=0.001, g=9.81, eps=2.5; /* vaccum perimittivity =8.85e-12 */
real E_0=0.5e5;
real K0 = M_PI/4.; /* aggregation rate constant */
mu=0.077;
delta=(d_2/d_1);
e_ij=1.8e-10*pow(((2.*delta*(rho_w-rho_o)*(1.-delta)*g*d_1)/(3.*eps*pow((1.+delta),2.)*pow(E_0,2.))),-0.55);
V_ij=2.*(mu+1.)*(rho_w-rho_o)*pow(d_1,2.)*(1.-pow(delta,2.))*g/(3.*(3.*mu+2.)*mu_o);
agg_kernel = K0*pow((d_1+d_2),2.0)*V_ij*e_ij;
return agg_kernel;
maba is offline   Reply With Quote
Old   December 19, 2021, 06:26
pakk will become famous soon enough
Print some results to the screen. Maybe you made a mistake in typing the equations, and your rate is billions times too high or too low.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   December 20, 2021, 11:21
Amin
The solution didn't start and iterate. What is the appropriate range of aggregation rate for the model? I know the unit of every parameter, except the
diameter. I assumed that the unit is meter. Is that correct?
Old   December 20, 2021, 15:29
I understand that you did not get a result, that's why I tell you to print the value to the screen.
Change your UDF so that it prints the value to the screen, using Message(). Then compare that value to the value that you used in the models that did work.
Old   December 25, 2021, 05:06
Amin
I printed the udf values, it is as follows:
a=...e-16
a=-nan(ind)
a=...e-17
a=-nan(ind)
What does the "-nan(ind)" mean?
Old   December 25, 2021, 08:09
It means a problem happened, like dividing be zero, and the result is not a number (nan=Not A Number).
To find out where it went wrong, print more intermediate results. Vij and Eij are good choices.
Old   December 25, 2021, 08:26
Ignoring the Nan, your values are very low, numerically. I really don't know which values you expect, so I can not say that they are wrong, but I would surely verify that if I were you.
Old   December 27, 2021, 05:58
Amin
Thank you very much pakk. The problem solved. It was duo to dividing by zero in Eij. Because in some cases, the ratio of diameter(delta) became one.
population balance method, udf converge
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
Fluidized Bed: Error: Divergence detected in AMG solver: pressure correction Error Ob Mole89 FLUENT 5 April 12, 2014 10:32
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
