UDF-Simulation of moisture transport in drying |
December 13, 2021, 13:04 |
John
Rep Power: 5 |
Please help:
I am trying to simulate the drying of particles in a chamber. For this purpose, I am using a UDF for mass and energy source terms. While interpreting the function, no errors are displayed. However, while initializing the solution I get an error "received a fatal signal (Segmentation fault)". There is also a warning which points out three lines in the UDF functions. Those lines are as follows: real Tabs, TC, W, w, pe, re, drebydpe, We, Source_w, psat,drying_constant; real Tabs,TC,physical_dt,W, We, w, pe, re,Wnew,psat; real pe, re, We, we, dwsebydt, Source_t; Note: I am using Fluent 18. in serial mode, double precision |
December 13, 2021, 14:12 |
Rep Power: 27 |
These lines are not enough info to find the problem.
It's better to give the full code.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
December 14, 2021, 05:15 |
UDF code
John
Rep Power: 5 |
Dear Friend, Please see the full code for moisture transport
#include "udf.h" /* Chung-Pfost constants */ #define ACP 921.69 #define BCP 18.077 #define CCP 112.35 #define RHOB 639.2 #define PATM 101325 /* Define ambient temperature conditions */ #define TMEAN 288.15 #define TAMP 5 /* Define a global variable that acts as a */ /* comparitor in DEFINE_ADJUST */ int last_ts = -1; DEFINE_INIT(moisure_init,d) /* The initial solids moisture content, W, is set */ /* and the corresponding humidity, w, of the */ /* intergranular air is calculated */ { cell_t c; Thread *t; real W,Tabs,TC,r,psat,p,w; /* Loop over all of the cell threads in the bulk of grain */ thread_loop_c(t,d) { begin_c_loop(c,t) { C_UDMI(c,t,0) = 0.1364; W = C_UDMI(c,t,0); Tabs = C_T(c,t); TC = Tabs-273.15; /* Calculate relative humidity of intergranular air, Eqn 11. */ r = exp(-ACP/(TC+CCP)*exp(-BCP*W)); /* Ensure the air does not become supersaturated */ if(r>0.99) {r = 0.99;} psat = 6.0e25/pow(Tabs,5) *exp(-6800/Tabs); p = r*psat; w = 0.622*p/(PATM-p); /* Eqn 12 */ C_UDSI(c,t,0) = w; } end_c_loop(c,t); } } DEFINE_SOURCE(mass_source,c,t,dS,eqn) { real Tabs, TC, W, w, pe, re, drebydpe, We, Source_w, psat,drying_constant; Tabs = C_T(c,t); TC = Tabs-273.15; psat = 6.0e25/pow(Tabs,5) *exp(-6800/Tabs); W = C_UDMI(c,t,0); w = C_UDSI(c,t,0); /* The post-fix ‘e’ denotes variables that relate to the equilibrium moisture content, We. */ pe = w*PATM/(0.622+w); re = pe/psat; We = -1/BCP*log(-(TC+CCP)/ACP*log(re)); /* Eqn 6 */ drying_constant = 2000*exp(-5094/Tabs); /* Eqn 5 */ C_UDMI(c,t,3) = re; C_UDMI(c,t,2) = We; /* Eqn3: */ C_UDMI(c,t,1) = -RHOB*drying_constant*(W-We); Source_w = -C_UDMI(c,t,1); dS[eqn] = 0.0; return Source_w; } DEFINE_ADJUST(update_mc,d) { real Tabs,TC,physical_dt,W, We, w, pe, re,Wnew,psat; cell_t c; Thread *t; /* The integer time step count (accessed using N_TIME) */ /* is useful in DEFINE_ADJUST functions for detecting */ /* whether the current iteration is the first in the */ /* time step. */ int curr_ts; curr_ts = N_TIME; if (last_ts != curr_ts) { last_ts = curr_ts; printf ("ADJUST: iteration = %d , = = = =\n", curr_ts); physical_dt = RP_Get_Real("physical-time-step"); /* Loop over all of the cell threads in the porous region */ thread_loop_c(t,d) { begin_c_loop(c,t) { Tabs = C_T(c,t); TC = Tabs-273.15; psat = 6.0e25/pow(Tabs,5) *exp(-6800/Tabs); W = C_UDMI(c,t,0); w = C_UDSI(c,t,0); /* The post-fix ‘e’ denotes variables that relate to the equilibrium moisture content, We */ pe = w*PATM/(0.622+w); /* Eqn 7 */ re = pe/psat; We = -1/BCP*log(-(TC+CCP)/ACP*log(re)); /* Eqn 6 */ Wnew = W+C_UDMI(c,t,1)*physical_dt/RHOB;/* Eqn 10 */ W = Wnew; C_UDMI(c,t,0) = W; } end_c_loop(c,t) } } } DEFINE_SOURCE(hygro_source,c,t,dS,eqn) { real Tabs, TC, w, psat, dpsatdt, drdt, hsbyhv, hs; real pe, re, We, we, dwsebydt, Source_t; /* The post-fix ‘e’ denotes variables that relate to the equilibrium moisture content, We, */ Tabs = C_T(c,t); TC = Tabs-273.15; we = C_UDSI(c,t,0); psat = 6.0e25/pow(Tabs,5) *exp(-6800/Tabs); pe = we*PATM/(0.622+we); re = pe/psat; We = -1/BCP*log(-(TC+CCP)/ACP*log(re));/* Eqn 6 */ dpsatdt = psat/Tabs*(-5+6800/Tabs); /* see Eqn 16 */ drdt = ACP*re/pow((TC+CCP),2)*exp(-BCP*We); /*Eqn 17 */ hsbyhv = 1+psat/re*1/dpsatdt*drdt; /* Eqn 15 */ hs = hsbyhv*(2501.33-2.363*TC)*1.0e3; C_UDMI(c,t,4) = hs; Source_t = C_UDMI(c,t,1)*hs;/* Eqn 14 */ dS[eqn] = 0.0; return Source_t; } |
December 14, 2021, 08:17 |
Alexander
Rep Power: 34 |
did you allocate memory for UDMS and UDS?
best regards ****************************** press LIKE if this message was helpful |
December 14, 2021, 14:33 |
Rep Power: 27 |
Initialize without this UDF. Your source tries to read temperature, but during initialization it is not set yet.
December 22, 2021, 07:08 |
reply
John
Rep Power: 5 |
Thank you, Alexander and pakk for your suggestions.
UDF species transport | qntldoql | Fluent Multiphase | 1 | June 5, 2021 23:25 |
Moisture diffusion by species transport between air and porous desiccants | jas123 | FLUENT | 1 | April 14, 2019 14:51 |
UDF Parse Error - Initializing VOF for Multiphase Simulation | denbjornen | Fluent UDF and Scheme Programming | 0 | April 25, 2018 03:07 |
Terminate transient simulation with UDF | Saman95 | Fluent UDF and Scheme Programming | 2 | April 16, 2018 05:57 |
URGENT - Simulation setup using Reynolds Tensor Transport (R) - OpenFOAM | beluiz93 | OpenFOAM | 1 | December 2, 2016 07:51 |
