increase
Old   December 7, 2021, 09:09
Default increase
R. Evon
Seven7 is on a distinguished road
Hi everyone,
I'm looking for a water tap to attach on a mass flow inlet of a multiphase simulation (No air from the tap). I'm not familliar with UDF programming (this one would be my first one).
I have found an example as basic:
#include "udf.h"
DEFINE_PROFILE(inlet_mf,th,i)
face_t f;
begin_f_loop(f,th)
if(CURRENT_TIME <= 10.0)
F_PROFILE(f,th,i) = 14.0;
else if(CURRENT_TIME <=10.0 && CURRENT_TIME >40.0)
F_PROFILE(f,th,i) = xxx.0;
else
F_PROFILE(f,th,i) = 2100.0;
end_f_loop(f,th);
by the xxx in the UDF I would like to open the tap linear, like in the attached picture.
is this easyer to do with Enter the Expressions Directly into the Fluent UI or ist this a typical UDF task?
Seven7
Seven7 is offline   Reply With Quote
Old   December 14, 2021, 08:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
for this statement
F_PROFILE(f,th,i) = xxx;
instead of xxx you need linear equation
y= kx + b
where you need to find k and b , but y = 14 if x = 10 sec and y = 2100 if x = 40 sec
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Fluent meshing: increase the max octree memory Ames FLUENT 1 November 9, 2021 09:58
cd increase but cl remains constant as AOA increase - possible? quarkz OpenFOAM Post-Processing 0 October 8, 2020 04:43
Increase in flow rate decrease in Outlet pressure. trovilb1 System Analysis 1 December 5, 2017 08:22
Extremely Small Constant Increase of Heat Transfer Coefficient With Concentration Shomaz ul Haq CFX 6 July 9, 2017 09:06
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
