Rep Power: 8 ![]() |
I am trying to write a mass transfer udf. to calculate mass transfer, i need contact area between liquid and air. would you please help me how can I find the contact area in udf which is the height of cell (2d) ? Thanks, |
Rep Power: 26 ![]() |
Do you want to extract the mass transfer from your simulation, or prescribe the mass transfer in your simulation?
If it is the first: you might not need to know the contact area, think of conservation of mass... If it is the second: then you need to define the contact area in your geometry.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
#3 | |
S = Kg*(Wgb-Wge)*A Which A is contact area. I am calculating this value for each cell, since the cell size is growing from inlet, I am looking for a way to calculate cell height for each cell? |
cell size, mass transfer vof udf, udf |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
Modifying Contact Detection UDF for 3D | wcj1n18 | Fluent UDF and Scheme Programming | 9 | March 17, 2021 23:33 |
Dynamic Contact Angle UDF in Fluent | codyn | Fluent UDF and Scheme Programming | 2 | August 24, 2016 23:54 |
how to use UDF to obtain the thred of the interface between the liquid and the wall? | hellowqy | Fluent UDF and Scheme Programming | 8 | December 17, 2015 10:03 |
UDF for varying contact angle (wettability gradient)) | aviitkgp1 | FLUENT | 1 | March 10, 2010 14:37 |
