Gradient of UDS is zero while UDS has non-zero values
Old   November 21, 2021, 21:36
Post Gradient of UDS is zero while UDS has non-zero values
YF
foolfishzju is on a distinguished road
Hi everyone,
I would like to get the gradient of species mass concentration to compute the mass transfer coefficient based on Fick's law. The code runs in parallel mode.
I am stuck with the issue of getting zero gradients of UDS. But when I check the value of UDS, there are non-zero values.
My UDF code is as below,
#include "udf.h"
DEFINE_ADJUST(spec_interf_concen,mixture_domain)
#if !RP_HOST
int liq_phase_id = 0;
int gas_phase_id = 1;
int co2_species_id = 0;
int yi = 0;
Domain *pDomain = DOMAIN_SUB_DOMAIN(mixture_domain,gas_phase_id);
Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL);
Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL);
Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate);
mp_thread_loop_c(mix_thread, mixture_domain, pt)
if (FLUID_THREAD_P(mix_thread))
begin_c_loop(c,mix_thread)
liq_thread = THREAD_SUB_THREAD(mix_thread,liq_phase_id);
gas_thread = THREAD_SUB_THREAD(mix_thread,gas_phase_id);
C_UDSI(c,pt[liq_phase_id],yi) = C_YI(c,pt[liq_phase_id],co2_species_id);
if((vof_l_c > 1e-6)&&(vof_l_c < 0.999999))
ca = press/KH_px*rho_l/Ml*vof_l_c;
C_UDSI(c,pt[liq_phase_id],yi) = ca*Mg/(ca*Mg+rho_l*vof_l_c);
end_c_loop_int(c,mix_thread)
/* Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NU LL); */
#endif
DEFINE_LINEARIZED_MASS_TRANSFER(surface_renewal, c, mixture_thread, from_phase_index, from_species_index, to_phase_index, to_species_index, lin_from, lin_to)
Thread *liq;
Thread **pt;
int liquid_species_id = 0;
int gas_phase_ID = 1;
int yi = 0;
real rho_l, rho_g, r_rho_lg;
real cg_G[3];
liq = THREAD_SUB_THREAD(mixture_thread, to_phase_index);
pt = THREAD_SUB_THREADS(mixture_thread);
rho_l = C_R(c,liq);
rho_g = C_R(c,pt[gas_phase_ID]);
vof_l = C_VOF(c,liq);
vof_g = C_VOF(c,pt[gas_phase_ID]);
if (NULL != THREAD_STORAGE(liq,SV_UDSI_G(yi)))
/* gradient of species mass concentration */
NV_V(cg_G,=,C_UDSI_G(c,liq,yi));
Message("Magnitude of species mass concentration: %f \n",NV_MAG(cg_G));
else
NV_S(cg_G,=,0.0);
return m_source;
Moreover, I did the following setup to keep the memory from freeing:
/solve/set/expert
but the TUI shows the option is incompatible with the adaption in parallel. I wonder whether this option will affect the value of UDS gradient.
Yuan Fang
foolfishzju is offline   Reply With Quote
Old   November 23, 2021, 00:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
manual
the solver continually removes data from memory that it does not need. In order to retain the
gradient data (when you want to set up user-defined scalar transport equations, for example), you can
prevent the solver from freeing up memory by issuing the text command solve/set/expert and
then answering yes to the question, “Keep temporary solver memory from being freed?”
Note that when you do this, all of the gradient data is retained, but the calculation requires more
memory to run.
so looks like you can't access gradient data without this setting
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 23, 2021, 20:55
YF
Originally Posted by AlexanderZ View Post
manual
Hi Alexander,
Do you know how to fix this issue?
I found a similar topic in Ansys forum:
https://forum.ansys.com/discussion/1...on-not-only-in
A coordinator mentioned that there is an unofficial method retrieving the gradient values, but he did not give the solution.
Old   November 24, 2021, 04:41
Alexander
unofficial way is to use reconstruction gradient macros, which you are using already
 Alloc_Storage_Vars(...)
 Scalar_Reconstruction(...)
 Scalar_Derivatives(...)
 Free_Storage_Vars(...)
you may check if memory for temperature gradient is allocated or not using following code
thread_loop_c(t, d)
 if (!SV_ALLOCATED_P(t, SV_T)) {
 Message("Energy Equation not active in zone %d on compute
 node %d\n", THREAD_ID(t), myid);
 } else {
 Message("Energy Equation active in zone %d on compute node
best regards
mass fraction (y), uds gradient of scalar, zero gradient
reconstruct gradient of UDS loving_cfd FLUENT 10 May 18, 2020 09:39
temperature gradient source term in uds cfd_mech FLUENT 0 July 27, 2014 05:55
non-exact gradient values elisabet OpenFOAM Programming & Development 3 July 18, 2012 08:45
reconstruction gradient of a UDS gemini Fluent UDF and Scheme Programming 0 June 7, 2009 17:03
Gradient UDS tom FLUENT 1 April 28, 2006 04:46
