how can use the cell temperature of each cell from zone 1 in zone 2 with UDF?
Old   November 14, 2021, 07:11
Default how can use the cell temperature of each cell from zone 1 in zone 2 with UDF?
wcs
bhwcs is on a distinguished road
I want to use the cell temperature of zone 1 in the source term of zone 2.
In the code i calculated the temperature of each cell in zone 1 and return it us function, but the problem is :in the fluent,zone 2 copy from zone1,and it's thread ID is 12, so in the UDF i use if(THREAD_ID(aux_t) == 12) to loop cell value,but it can't loop .The problem I am currently experiencing is that zone2 is copied from zone1, so the loop function cannot be run
begin_c_loop(aux_c,aux_t)
C_CENTROID(aux_x,aux_c,aux_t);
Message( "in thread=%g \n",1.0);
a_x=aux_x[0];
a_y=aux_x[1];
a_z=aux_x[2];
Message( "a_x=%g a_y=%g C_T(aux_c,aux_t)=%g THREAD_ID=%d\n",a_x,a_y,C_T(aux_c,aux_t),THREAD_ID (aux_t));
if(a_x==x && a_y==y && a_z==z )
aux_tem=C_T(aux_c,aux_t);
end_c_loop(aux_c,aux_t)
Do anybody have an idea how i can use the cell temperature of each cell from zone 1 in zone 2 ? Both zones have same number of cells and same dimensions.
by the way, i dont konw how to upload a pitcture in this txt...anybody can give me a message
bhwcs is offline   Reply With Quote
Old   November 15, 2021, 04:58
pakk will become famous soon enough
I may be blind, but I don't see your code.
Secondly: what does your problem physically represent?
You have to zones, and the temperature in one zone determines the source of another zone? The zones are not in the same place, so by what magic should that work?
(You have the right to implement this, don't get me wrong, but I just want to know for sure that I understand what you are trying to do, because from what I understand now it is very, very strange...)
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   November 15, 2021, 05:07
wcs
Dear pakk,thanks for your reply.this is my UDF code blow here
DEFINE_SOURCE(primary,c,t,dS,eqn)
int i;
real D_X=0.002;
real D_Y=0.001;
real D_Z=0.0025;
real pri_tem=0.0;
double ppri_x;
int num_x=0;
int num_y=0;
int num_z=0;
real tem_1=0.0,tem_2=0.0;
real source=0.0;
real volume=0.0;
real cp=0.0;
double x[ND_ND]; //array for storing the centroid position
face_t f;
real massflow=0;
double tem;
double *m;int n;
Thread *f_thread;
double pri_x=0.0;
double pri_y=0.0;
double pri_z=0.0;
double weizhi;
C_CENTROID(x,c,t);
pri_x=x[0];
pri_y=x[1];
pri_z=x[2];
tem= temp(pri_x,pri_y,pri_z);
volume=C_VOLUME(c,t);
cp=C_CP(c,t);
num_x=ceil(x[0]/D_X);
num_y=ceil((x[1]-0.005)/D_Y);
num_z=ceil(x[2]/D_Z);
c_face_loop(c,t,n)
f=C_FACE(c,t,n);
f_thread = C_FACE_THREAD(c,t,n);
if(F_FLUX(f,f_thread)<0)
massflow=massflow+F_FLUX(f,f_thread);
weizhi=C_UDMI(c,t,0);
Message( "pri_x=%g pri_y=%g pri_z=%g weizhi=%g\n", pri_x,pri_y,pri_z,weizhi);
source = fabs(massflow)*cp*(600-C_T(c,t))/(volume);
dS[eqn] = 0;
return source;
double temp(double x, double y,double z)
double aux_tem,aux_temp;
double a_x,a_y,a_z;
int ID=12;
double aux_x[ND_ND];
Domain *domain;
Thread *aux_t;
cell_t aux_c;
domain=Get_Domain(1);
aux_t= Lookup_Thread(domain, ID);
thread_loop_c(aux_t,domain)
Message( "THREAD_ID=%d \n",THREAD_ID(aux_t));
//if(THREAD_ID(aux_t) == 12)
a_x=aux_x[0];
a_y=aux_x[1];
a_z=aux_x[2];
return aux_tem;
THe problem is :in the fluent,zone 2 copy from zone1,and it's thread ID is 12, so in the UDF i use if(THREAD_ID(aux_t) == 12) to loop cell value,but it can't loop .
I want to use this kind of problem to simulate a heat exchanger. You know, one side(zone1)is cold flow, and the other side(zone2) is heat flow.
In addition, my question is very similar to the one mentioned in this article, you can refer to his question and picture。https://forum.ansys.com/discussion/1...-a-written-udf
Old   November 15, 2021, 07:45
So you have two 3D volumes, and the temperature of volume 1 determines the source of volume 2? Huh? That is not how heat exchangers work... Please explain better, because how I understand it is so silly, I'm sure that's not what you mean, but I can't guess what you really mean.
Normally, hot zones and cold zones interact through the surface in between them. Isn't that what you are after?
Old   November 15, 2021, 08:41
wcs
Let me explain in detail. In fact, this is a process of simulating a double grid heat exchanger in Fluent. The heat source formula q=KA(T,cell,aT,cell,p); through this formula, we can see that zone1 is used to represent the heat source , Zone2 represents cold flow. They have the same structure during grid division, but belong to different parts, so they have different threads in fluent, so when calculating q in zone2, you need to get the temperature of each grid in zone1, so as to get the heat source term , Similarly applying similar heat source terms in zone1, the two zones can be coupled to calculate heat exchange.
Refer to the UDF I wrote so far. The problem I have encountered is that when I apply the sorce item in zone2, the temperature of zone1 cannot be returned. The reason I guess is that zone2 and zone1 are physically separated, but I don’t have a better Solution.
NOW i find the problem is the macro begin_c_loop_int(c,tt){...}end_c_loop_int(c,tt) Not work when running in parallel, but when running in serial,do u know how to fix this problem?
Old   November 15, 2021, 13:39
No, but I would then advice to look in the manual for begin_c_loop_int.
I don't think you should explain further, I don't think that is useful, but just in case: I still don't follow.
You say about the volumes "They have the same structure during grid division, but belong to different parts", but that is unclear... Does that mean that they share the same physical volume? If not, are they far away from each other or touching?
I indicated what was strange about your setup, but your answer kind of ignores these issues. Maybe you did not understand what I meant, in that case I only have myself to blame.
Old   November 16, 2021, 00:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
from my point of view in case zones are phisically separated (so cell/thread loop starts counting cell again when you go from one zone to another)
you need to find the link between each cell from zone 1 to each cell in zone 2.
to do that I would make a loop over all cells in zone 1 (zone where is your temperature) and in each cell would loop over cells from zone 2, checking coordinates.
as you know how far zone 1 from zone 2 its pretty easy. (we assume that grids are identical as you've mentioned)
So using DEFINE_ON_DEMAND(name) function you may find this link
code could look like this
compile code, I didn't debug
#include "udf.h"
DEFINE_ON_DEMAND(get_link)
	Domain *d;
	cell_t c1,c2;
	Thread *t1,*t2;
	static int ID_1 = 1;
	static int ID_2 = 2;
	real cell1[ND_ND],cell2[ND_ND];
	real distance_x = 0.1; // distance between zone 1 and zone 2 in x-direction
	real delta = 1e-6;	// half of smallest cell in grid
	d = Get_Domain(1);
	t1= Lookup_Thread(d, ID_1);
	t2= Lookup_Thread(d, ID_2);
	begin_c_loop_int(c1,t1)
		C_CENTROID(cell1,c1,t1);
		begin_c_loop_int(c2,t2)
			C_CENTROID(cell2,c2,t2);
			if (cell2[0] <= cell2[1] + distance + delta) && (cell2[0] >= cell2[1] + distance - delta)
				C_UDMI(c2,t2,0) = c1;
				C_UDMI(c2,t2,1) = C_T(c1,t1); // no nessesary here
				break;
		end_c_loop_int(c2,t2)
	end_c_loop_int(c1,t1)
	Message0("On_demand has beeen executed\n");
DEFINE_ADJUST(apply_temperature,d)
	cell_t c1,c2;
	Thread *t1,*t2;
		c1 = C_UDMI(c2,t2,0);
		C_T(c2,t2) = C_T(c1, t1);
		C_UDMI(c2,t2,1) = C_T(c1, t1); // just to have additional monitor with modifications
	Message0("temperature has been applied\n");
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 16, 2021, 07:34
wcs
#include "udf.h"
	Domain *d;
	cell_t c1,c2;
	Thread *t1,*t2;
	d = Get_Domain(1);
				break;
	cell_t c1,c2;
	Thread *t1,*t2;
Dear AlexanderZ, thank you very much for your recovery, your UDF is very helpful. I have tried to run your UDF, and the problem I encountered is the same as I described before, that is,whem FLUENT run in parallel, the following loop,
begin_c_loop_int(c1,t1){..}end_c_loop_int(c1,t1) is accessible, but begin_c_loop_int(c2,t2){...}end_c_loop_int(c2,t2) can’t run, . I tried to fix it and found that it can go from c1 to c2 in serial, but not in parallel. The reason is that FLUENT loops in zone1 area when parallel with multi computer nodes (that is, begin_c_loop_int(c1,t1){..}end_c_loop_int( c1,t1)) is on the computing node node(i), but the loop in zone1 (that is, begin_c_loop_int(c2,t2){...}end_c_loop_int(c2,t2)) is on another computing node node(j). This is the crux of the problem, and I cannot get the temperature of zone2 from zone1. Do you have any good suggestions for parallel and serial.
Old   November 17, 2021, 01:02
Alexander
well, I have no idea how to fix this issue with loops.
you may go other way, write profile. It will contain coordinates and temperature (for instance), modify coordinates and apply it:
-you may try to read that modified profile and apply directly. In that case fluent will interpolate automatically. THIS MUST BE CHECKED
-you may read it through UDF and interpolate by your own function (or applied in other way)
best regards
Old   November 17, 2021, 03:20
wcs
thans for your advice~~best regard
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
Possible to loop a face thread inside a cell thread loop? MarcusW FLUENT 3 March 7, 2012 07:32
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
