November 3, 2021, 06:27 |
How to parallelize the UDF code
Qingshan Liu
Rep Power: 5 |
I encountered a problem while parallelizing the UDF code. For the following code, the results of using serial (1 CPU thread) calculation and parallel (15 CPU threads) calculation are different. The following is the original code (no parallelization operation):
#include "udf.h" double CLP=0; double T=0; double TER=(110.0*M_PI/180.0); double DCA=110.0; int FT=1; double CV=0; FILE *file; double S=0.0,R; DEFINE_ADJUST(CAP, domain) { Thread *thread = Lookup_Thread(domain, 1); Thread **pt = THREAD_SUB_THREADS(thread); cell_t cell; face_t f; real x[ND_ND]; double MX=0, FHI, XH, TE, Ca, VO; int n; S=0.0; begin_c_loop_all (cell,pt[1]) { if(C_VOF(cell,pt[1])!=0) { C_CENTROID(x,cell,pt[1]); if(x[0]>MX) MX=x[0]; } S+=C_VOF(cell,pt[1]); } end_c_loop_all (cell,pt[1]) R=sqrt(S*1.0e-08/M_PI); printf("MX=%f R=%f CV=%f T=%f DCA=%f S=%f\n",MX,R,CV,T,DCA,S); if(FT==0) { CV= (R-CLP)/(RP_Get_Real("flow-time")-T); CLP = R; T=RP_Get_Real("flow-time"); Ca = CV*1e-3/0.0728; TE= 0.5-0.5 * cos(TER); TE= 0.5 * log( (1.0+TE)/(1.0-TE) ); FHI = -(9.78 * pow( TE,1.41))/(12.81 * pow(TE,1.41)-100.0); XH= Ca + FHI ; if(CV>=0) DCA= acos( 1-2*tanh(5.16*pow((XH/(1+1.31*pow(XH,.99))),0.706) ) ) *180.0/M_PI ; else DCA= 2*TER*180.0/M_PI -acos( 1-2*tanh(5.16*pow((XH/(1+1.31*pow(XH,.99))),0.706) ) ) *180.0/M_PI ; file = fopen("file.txt", "a+"); fprintf(file,"MX=%f R=%f CV=%f T=%f DCA=%f\n",MX,R,CV,T,DCA); fclose(file); if(R>1e-18 && FT==1) { CLP = R; T=RP_Get_Real("flow-time"); FT=0; file = fopen("file.txt", "a+"); fprintf(file,"MX=%f R=%f CV=%f T=%f\n",MX,R,CV,T); fclose(file); } } DEFINE_PROFILE(CAS,t,i) { face_t f; begin_f_loop(f,t) { F_PROFILE(f,t,i) = DCA; } end_f_loop(f,t) } Last edited by brucelqs; November 4, 2021 at 03:22. |
November 3, 2021, 23:31 |
Alexander
Rep Power: 34 |
#include "udf.h" double contact_line_position = 0; double time = 0; double theta_e_radian = (110.0 * M_PI / 180.0); double dynamic_contact_angle = 110.0; int first_time = 1; double contact_velocity = 0; FILE* file; double sum = 0.0, R; DEFINE_ADJUST(Contact_Angle_Update, domain) { Thread* thread = Lookup_Thread(domain, 9); Thread** pt = THREAD_SUB_THREADS(thread); cell_t cell; face_t f; real x[ND_ND]; double max_x = 0, f_Hoff_inverse, x_hoff, temp, Ca, volume; int n; sum = 0.0; begin_c_loop_all(cell, pt[1]) { if (C_VOF(cell, pt[1]) != 0) { C_CENTROID(x, cell, pt[1]); if (x[0] > max_x) max_x = x[0]; } sum += C_VOF(cell, pt[1]); } end_c_loop_all(cell, pt[1]) #if RP_NODE sum = PRF_GRSUM1(sum); #endif R = sqrt(sum * 1.0e-08 / M_PI); Message0("max_x=%f R=%f contact_velocity=%f time=%f dynamic_contact_angle=%f sum=%f\n", max_x, R, contact_velocity, time, dynamic_contact_angle, sum); if (first_time == 0) { contact_velocity = (R - contact_line_position) / (RP_Get_Real("flow-time") - time); contact_line_position = R; time = CURRENT_TIME; Ca = contact_velocity * 1e-3 / 0.0728; temp = 0.5 - 0.5 * cos(theta_e_radian); temp = 0.5 * log((1.0 + temp) / (1.0 - temp)); f_Hoff_inverse = -(9.78546 * pow(temp, 1.416430594900850)) / (12.819 * pow(temp, 1.41643) - 100.0); x_hoff = Ca + f_Hoff_inverse; if (contact_velocity >= 0) dynamic_contact_angle = acos(1. - 2. * tanh(5.16 * pow((x_hoff / (1. + 1.31 * pow(x_hoff, .99))), 0.706))) * 180.0 / M_PI; else dynamic_contact_angle = 2. * theta_e_radian * 180.0 / M_PI - acos(1. - 2. * tanh(5.16 * pow((x_hoff / (1. + 1.31 * pow(x_hoff, .99))), 0.706))) * 180.0 / M_PI; node_to_host_real_5(max_x, R, contact_velocity, time, dynamic_contact_angle); #if RP_HOST file = fopen("file.txt", "a+"); fprintf(file, "max_x=%f R=%f contact_velocity=%f time=%f dynamic_contact_angle=%f\n", max_x, R, contact_velocity, time, dynamic_contact_angle); fclose(file); #endif if (R > 1e-18 && first_time == 1) { contact_line_position = R; time = CURRENT_TIME; first_time = 0; #if RP_HOST file = fopen("file.txt", "a+"); fprintf(file, "max_x=%f R=%f contact_velocity=%f time=%f\n", max_x, R, contact_velocity, time); fclose(file); #endif } } } DEFINE_PROFILE(Contact_Angle_Set_Profile, t, i) { face_t f; begin_f_loop(f, t) { F_PROFILE(f, t, i) = dynamic_contact_angle; } end_f_loop(f, t) }
best regards ****************************** press LIKE if this message was helpful |
November 4, 2021, 00:38 |
Qingshan Liu
Rep Power: 5 |
Thank you very much for your reply. I tried this code and found that in the case of 1 CPU thread (serial) and 16 CPU threads (parallel), the results obtained in parallel will diverge and terminate in the later stage of the calculation. This problem should not be a UDF code problem, the specific reason remains to be resolved.
UDF Error at Node 0: Error code: 126 | a.maroofi | Fluent UDF and Scheme Programming | 3 | January 29, 2020 07:50 |
UDF Code doesn't work | force_95 | FLUENT | 7 | October 30, 2019 01:19 |
Compiling the customized UDF code for PEMFC | dmfo | Fluent UDF and Scheme Programming | 2 | October 1, 2017 19:30 |
write code UDF Fluent solve kinetic reaction rate equation palm oil | zirkov | FLUENT | 0 | February 13, 2017 11:16 |
Parallelize UDF help | Rhyno466 | Fluent UDF and Scheme Programming | 1 | February 14, 2012 15:49 |
