Transient and Parabolic inlet velocity
Old   October 28, 2021, 03:22
Default Transient and Parabolic inlet velocity
YADU KRISHNAN N
Yadu krishnan is on a distinguished road
How can I define an inlet velocity varies both wrt time(sinusoidally) and y direction(Parabolic) using UDF ?
Yadu krishnan is offline   Reply With Quote
Old   October 28, 2021, 05:20
pakk will become famous soon enough
In the same way as you do a parabolic profile, but with a different equation.
This is not a UDF problem, but a physics/mathematics problem.
(to be clear: you are free to ask this question here, but I want to point you in the right direction for solving it. The solution is not in combining UDFs or doing complicated things in a UDF. The solution is in finding the equation that you need to put in the UDF, once you have that equation it is very easy.)
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Laminar flow: steady-state or transient? Ames FLUENT 4 March 25, 2021 13:38
Transient parabolic 3D velocity profile mattialupo Fluent UDF and Scheme Programming 1 October 15, 2019 08:35
UDF for Inlet of an Aorta 3D, parabolic, pulsatile flow MagnusJohannes Fluent UDF and Scheme Programming 1 April 3, 2018 20:54
Volume flow rate boundary condition in OpenFOAM mayank.dce2k7 OpenFOAM Running, Solving & CFD 13 August 11, 2014 21:16
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 17:10
