UDF operates as a function of liquid fraction
Old   October 22, 2021, 16:38
Default UDF operates as a function of liquid fraction
Erfan
erfan2000 is on a distinguished road
Hello dear all
I am new to Fluent and I have a problem with writing a UDF.
I have a case consisting of phase change material(PCM) that is fully solid at first and a mini-channel with the water inlet on top of that. want to write a UDF to change water inlet velocity as PCM liquid fraction reaches 0.2.
the liquid fraction is defined in the report definition.
Thanks in advance
erfan2000 is offline   Reply With Quote
Old   October 25, 2021, 01:15
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
to control boundary condition one may use DEFINE_PROFILE macro
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
pcm, udf, velocity
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Can I define density in terms of liquid fraction in UDF? mariam.sara Fluent UDF and Scheme Programming 21 August 26, 2019 00:56
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
