October 19, 2021, 17:57 |
UDF to correct the wall-normal fluctuation
imane
Rep Power: 8 |
hello!
I m about to model particle deposition using the RSM model combined with the EWT and the DRW to model the particle turbulent dispersion, however, the deposition is dependent on the normal fluctuating velocities thus the RSM needs to be corrected based on experimental data. the question is which Macro should I use to create my UDF program? I will be grateful if someone helps me!! thank you! Regards. |
August 3, 2022, 10:31 |
Shuvo Chowdhury
Rep Power: 4 |
Hello, have you got any solution. I am also stuck at this problem
Ansys CFD-Post Application Error | rushiCFD | FLUENT | 0 | March 21, 2021 08:51 |
How to use a UDF to set the volume fraction in the cells next to a wall? | DF15 | Fluent UDF and Scheme Programming | 33 | August 20, 2020 14:36 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
UDF for fluxes normal to a wall | Leverkin | FLUENT | 0 | December 10, 2007 13:04 |
