Adding Variables to Display Titles from an UDF or Scheme
Old   October 12, 2021, 05:27
Question Adding Variables to Display Titles from an UDF or Scheme
anan12345 is on a distinguished road
Hello, does anyone has any experience with adding a variable to the display titles?
For an example I would like to have a changing variable just like time which is implemented by default to a transient analysis animation. I have enabled this by File>Preferences>Appearance>Titles
In fluent TUI, I have found that Title names can be customized. I would like to add another dynamic variable that changes over time to the animation display.
Any help would be appreciated. Thanks!
anan12345 is offline   Reply With Quote
Old   October 12, 2021, 23:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
there is an option to add annotations
display> annotate title
but you should click on the screen to place it, so I don't see an option to make it dynamic
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 13, 2021, 04:02
The main problem with what you suggested and what I'm trying to do is that fluent accepts string inputs for those commands.
I did try something like (format #f "Moment Z is ~a" <variable>) with all its possible variants I could think of, but inside the string input quotation marks are not accepted.
Also, Fluent automatically updates the time part of the title, so in my opinion this should be possible in someway.
Old   October 15, 2021, 01:46
Alexander
if you need quotation marks you need to use \ before "
(format #f "Moment Z is \"~a\"" <variable>)
best regards
Getting density, temperature, and other cell flow variables via macros in Fluent UDF ingabobjoe Fluent UDF and Scheme Programming 2 August 15, 2020 22:08
Dynamic mesh using UDF and layering method - no dynamic mesh zones to display error HootanRahimi Fluent UDF and Scheme Programming 3 May 7, 2019 13:03
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
changing scheme variable with UDF? Wagemakers FLUENT 17 September 30, 2015 15:34
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 08:43
