October 11, 2021, 02:56 |
Output of BOUNDARY_HEAT_FLUX(f, thread)
YADU KRISHNAN N
Rep Power: 5 |
What does the function BOUNDARY_HEAT_FLUX(f, thread) returns in a UDF used in fluent. Wall heat flux density(W/m2) or wall heat (W) ? Does it return total heat flux? To access local heat flux density(W/m2) of a single cell, How can I use this function?
October 11, 2021, 10:31 |
#2 | |
Rep Power: 27 |
Did you know that Fluent has a manual?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
Forward simulations -- Evaluating objective function only without design modules | kensaii | SU2 Shape Design | 4 | April 25, 2020 16:12 |
What variable should I output to get wall force? | Pauli | CFX | 6 | May 15, 2018 08:58 |
Parallel UDF Segmentation fault error | KevinZ09 | Fluent UDF and Scheme Programming | 1 | January 9, 2017 06:30 |
Please check out my parallelized udf code | aleisia | Fluent UDF and Scheme Programming | 0 | June 10, 2011 17:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
