September 28, 2021, 08:10 |
UDF code for roll decay test of ship
MAI THI LOAN
Rep Power: 6 |
Dear all,
Does anyone know the UDF code for the roll decay simulation of the ship? I need your help with this problem Thank you in advance |
September 28, 2021, 14:56 |
Rep Power: 27 |
Is this part of a famous set of problems? Should I know which simulation "the roll decay simulation of the ship" is? Should I know which ship you are talking about?
I don't know which simulation you talk about. I don't know which ship you talk about. I don't know what the UDF should do. So I can not help with so little information.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
Urgent help for UDF Code needed | force_95 | FLUENT | 2 | October 25, 2019 08:35 |
Need help with udf code for particles | force_95 | FLUENT | 0 | October 24, 2019 09:58 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 03:48 |
Difficulty with UDF code for HEAT FLUX | etudiant_IITB | Fluent UDF and Scheme Programming | 1 | December 7, 2015 09:07 |
How to transfer a 2D UDF code into 3D? | Jo_vivian_lee | Fluent UDF and Scheme Programming | 0 | August 26, 2012 04:36 |
