Neumann boundary condition for heat flux using UDF
Old   September 10, 2021, 10:59
Default Neumann boundary condition for heat flux using UDF
YADU KRISHNAN N
Yadu krishnan is on a distinguished road
Trying to give Neumann boundary condition for heat flux using below UDF and getting error Error: received a fatal signal (Segmentation fault).
#include "udf.h"
#include "mem.h"
DEFINE_PROFILE(Heat_flux,thread,position)
cell_t c;
face_t f;
real x[ND_ND];
real cell[ND_ND];
int k = 1;
real wf;
real nc;
real temp;
real tempgrad ;
real Twall=300;
real delta;
begin_f_loop(f, thread)
F_CENTROID(x,f, thread);
wf = x[1];
c = F_C0(f,thread);
C_CENTROID(cell,c, thread);
nc = cell[1];
delta = wf-nc;
temp = C_T(c, thread);
tempgrad= (temp - Twall)/delta ;
F_PROFILE(f, thread, position) = k * tempgrad;
end_f_loop(f, thread)
Tried initializing and run a few iterations before loading UDF and not working.
Yadu krishnan is offline   Reply With Quote
Old   September 10, 2021, 15:34
pakk will become famous soon enough
Here is the problem: "thread" is a face thread, not a cell thread. You still need to find the cell thread for cell c.
I forgot how that works.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   September 12, 2021, 11:53
Default Problem with wall heat flux in supersonic flow related validation case
Tamil Nadu
aved is on a distinguished road
Hi!
I am doing a heat transfer to air from the hot wall which is almost a Rayleigh flow case kinda simulation. I wanted to do a validation but couldn't find a good experimental paper. Can anyone suggest me a paper?
Thanks!
aved is offline   Reply With Quote
Old   September 13, 2021, 02:49
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
as Pakk said you need to define cell and thread of the finite volume adjusted to face you are looping
you need to use macros:
F_C0(f,t);
THREAD_T0(t);
final code
#include "udf.h"
DEFINE_PROFILE(my_heat_flux,thread,position)
cell_t c0;
Thread *t0;
face_t f;
real x[ND_ND];
real cell[ND_ND];
int k = 1;
real wf;
real nc;
real temp;
real tempgrad ;
real Twall=300;
real delta;
wf = x[1];
c0 = F_C0(f,thread);
t0 = THREAD_T0(thread);
C_CENTROID(cell,c0, t0);
nc = cell[1];
delta = wf-nc;
temp = C_T(c0, t0);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 13, 2021, 11:22
YADU KRISHNAN N
Thanks. There is no error showing now. But when I load the udf for heat flux boundary condition and running the simulation, solution is not converged for cold flow without reaction. Below are the model parameters and BCs.
Energy equation - ON
Viscous - Laminar
Species transport - ON , H2&air mixture,No volumetric reactions
inlet BC : velocity = 0.3 m/s , Mass fraction of h2 =0.6,
Mass fraction of o2=0.23
wall BC : above UDF
Hybrid initialization.
The temperature contour is same from the beginning and not changing even after 5000 iterations and attached herewith.
Old   September 14, 2021, 01:53
Alexander
check the units of heat flux you are applying
best regards
Old   September 14, 2021, 08:53
YADU KRISHNAN N
Heat flux units are W/m2 which is in mismatch with UDF output. So if I access thermal conductivity of wall(W/mK) and store it in variable 'k' , will it work?
Or do i need to make temperature gradient non dimensional.
Heat flux UDF boundary condition on a wall KsaMe Fluent UDF and Scheme Programming 8 June 25, 2020 19:28
How to define Heat flux UDF in ansys in Boundary Condition? Azim07 FLUENT 1 August 16, 2019 01:28
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 22:55
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
UDF : Neumann boundary condition PierreM FLUENT 1 December 5, 2008 08:06
