Mass Transfer UDF for term in vector form
Old   September 9, 2021, 04:09
Default Mass Transfer UDF for term in vector form
Rabi Pathak
RabiArya is on a distinguished road
Mass transfer rate = D(n.grad(Cv))
where D is diffusivity of vapor to air
grad Cv is gradient of molar concentration of vapor
n is normal vector
RabiArya is offline   Reply With Quote
Old   September 9, 2021, 05:21
pakk will become famous soon enough
OK, thanks.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   September 9, 2021, 07:08
Rabi Pathak
Does anyone know how to write this in UDF code?
UDF for heat and mass transfer, transient simulation Akash Siddique Fluent UDF and Scheme Programming 7 December 7, 2018 07:32
UDF for heat and mass transfer Akash Siddique Fluent UDF and Scheme Programming 6 September 1, 2018 04:51
using define mass transfer udf for cavitation Komon Fluent UDF and Scheme Programming 14 June 21, 2016 03:50
Problems regarding mass transfer UDF Yifan_G Fluent UDF and Scheme Programming 8 December 8, 2014 11:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
