Volume flow rate per width
Old   August 22, 2021, 23:33
Default Volume flow rate per width
aminhgn is on a distinguished road
I am new to UDF. I would like to calculate volume flow rate of the unit width which is m3 m-1 s-1 and use this volume flow rate through define source function???
Thank you in advance for your help.
Amin
aminhgn is offline   Reply With Quote
define cell, flow rate, flowratevelocity, volume cell
Volume flow rate input smaugtheterrible FLUENT 0 June 30, 2020 13:30
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 15:19
volume flow rate error in udf jjchristophe Fluent UDF and Scheme Programming 1 July 13, 2010 05:23
