UDF loading error 126
Old   August 20, 2021, 02:26
Default UDF loading error 126
YADU KRISHNAN N
Yadu krishnan is on a distinguished road
Unable to load the UDF library after successful compilation using VS2019. Error is showing as
Opening library "D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf"...
Error at Node 0: Error code: 126
Error at host: Error code: 126
Error: Error code: 126\n
Error Object: #f
Yadu krishnan is offline   Reply With Quote
Old   August 20, 2021, 02:37
pakk will become famous soon enough
Are you sure there were no errors during compiling? People tend to miss the errors printed on the screen...
Is your UDF loading external modules? Are you doing something well beyond what's shown in the manual?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   August 20, 2021, 02:45
YADU KRISHNAN N
A warning is shown as
"UDF_Tempgrad.c(17) : warning C4700: uninitialized local variable 't' used " after building. UDF is as given below.
#include "udf.h"
DEFINE_ADJUST(adjust_fcn,d)
Thread *t;
Thread *tf;
cell_t c;
face_t f;
real x[ND_ND];
real cell[ND_ND];
int n;
real wf;
real nc;
real temp;
real tempgrad ;
real Twall=100;
real delta;
begin_c_loop_all(c,t)
c_face_loop(c,t,n)
tf = C_FACE_THREAD(c,t,n);
if(THREAD_TYPE(tf) == THREAD_F_WALL)
f = C_FACE(c,t,n);
F_CENTROID(x,f,t);
wf = x[1];
C_CENTROID(cell,c,t);
nc = cell[1];
delta = wf-nc;
temp = C_T(c,t);
tempgrad= (temp - Twall)/delta ;
end_c_loop_all(c,t)
Old   August 20, 2021, 05:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
UDF Error at Node 0: Error code: 126
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 20, 2021, 07:07
YADU KRISHNAN N
libudf and case file are located at same place. still geting error. Please see the complete console text.
> Copied D:\Project\CDmicro1_files\dp0\FFF-1\Fluent/D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\UDF_Tempgrad.c to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\sconstruct.udf "libudf\win64\2ddp_host\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\scons_default.bat "libudf\win64\2ddp_host\scons_test.bat" ")
1 file(s) copied.
Creating user_nt.udf file for 2ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_host")
D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf\win64\2ddp_host>rem
D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf\win64\2ddp_host>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
Microsoft (R) C/C++ Optimizing Compiler Version 19.29.30133 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
Microsoft (R) Program Maintenance Utility Version 14.29.30133.0
# Generating ud_io1.h
resolve.exe -udf ..\..\src\UDF_Tempgrad.c -head_file ud_io1.h
cl /c /Za /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -I. -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\win64\2ddp_host -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\main -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\addon-wrapper -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\io -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\species -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\pbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\numerics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\sphysics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\storage -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mphase -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\bc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\models -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\material -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\amg -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\util -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mesh -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\udf -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ht -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dx -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\turbulence -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\acoustics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\parallel -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\etc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ue -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dpm -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\cortex\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\client\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\tgrid\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\mpi_wrapper\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\inclu de ..\..\src\UDF_Tempgrad.c
UDF_Tempgrad.c
D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf\src\UDF_Tempgrad.c(17) : warning C4700: uninitialized local variable 't' used
# Generating udf_names.c because of makefile UDF_Tempgrad.obj
cl /c /Za /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -I. -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\win64\2ddp_host -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\main -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\addon-wrapper -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\io -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\species -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\pbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\numerics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\sphysics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\storage -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mphase -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\bc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\models -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\material -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\amg -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\util -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mesh -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\udf -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ht -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dx -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\turbulence -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\acoustics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\parallel -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\etc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ue -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dpm -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\cortex\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\client\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\tgrid\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\mpi_wrapper\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\inclu de udf_names.c
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj UDF_Tempgrad.obj
link /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent "\fluent21.1.0\win64\2ddp_host /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent "\fluent21.1.0\multiport\win64\net\shared /dll /out:libudf.dll udf_names.obj UDF_Tempgrad.obj mport.lib fl2110.lib
Microsoft (R) Incremental Linker Version 14.29.30133.0
Creating library libudf.lib and object libudf.exp
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\sconstruct.udf "libudf\win64\2ddp_node\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\scons_default.bat "libudf\win64\2ddp_node\scons_test.bat" ")
1 file(s) copied.
Creating user_nt.udf file for 2ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluent 21.1.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_node")
D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf\win64\2ddp_node>rem
D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf\win64\2ddp_node>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
cl /c /Za /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -I. -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\win64\2ddp_node -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\main -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\addon-wrapper -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\io -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\species -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\pbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\numerics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\sphysics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\storage -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mphase -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\bc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\models -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\material -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\amg -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\util -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mesh -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\udf -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ht -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dx -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\turbulence -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\acoustics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\parallel -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\etc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ue -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dpm -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\cortex\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\client\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\tgrid\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\mpi_wrapper\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\inclu de ..\..\src\UDF_Tempgrad.c
UDF_Tempgrad.c
cl /c /Za /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -I. -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\win64\2ddp_node -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\main -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\addon-wrapper -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\io -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\species -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\pbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\numerics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\sphysics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\storage -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mphase -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\bc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\models -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\material -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\amg -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\util -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\mesh -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\udf -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ht -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dx -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\turbulence -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\acoustics -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\parallel -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\etc -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\ue -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dpm -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\src\dbns -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\cortex\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\client\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\tgrid\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\fluen t21.1.0\multiport\mpi_wrapper\src -I"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent"\inclu de udf_names.c
udf_names.c
link /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent "\fluent21.1.0\win64\2ddp_node /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v211\fluent "\fluent21.1.0\multiport\win64\mpi\shared /dll /out:libudf.dll udf_names.obj UDF_Tempgrad.obj mport.lib fl_mpi2110.lib
Done.
LAPTOP-1PSN8BVE: Opening library "D:\Project\CDmicro1_files\dp0\FFF-1\Fluent\libudf"...
Error Object: #f
Old   August 20, 2021, 15:09
The uninitialized variable is also something you need to solve: you adjust thread "t" , but don't say what "t" refers to. But that is unrelated to error 126.
Is this the only udf with this problem? Have you successfully used UDFs before on this system?
Old   August 22, 2021, 01:10
YADU KRISHNAN N
I haven't done any UDFs in my system before. Checked some other UDFs. They are also showing problem.
How to use patch under loading UDF? lilistar-8216 Fluent UDF and Scheme Programming 4 May 17, 2019 04:31
Error code: 126 when loading parallel UDF Coop Fluent UDF and Scheme Programming 0 July 13, 2018 09:33
Problem loading UDF in Linux environment hjan23 FLUENT 0 December 15, 2017 05:09
(FLUENT)failed loading UDF source file sincity FLUENT 2 March 18, 2011 09:47
UDF Error while loading Sujay S FLUENT 8 November 12, 2007 23:30
