July 16, 2021, 04:52 |
Fluent Scheme Variable in Matlab AAS Mode
Amitav tikadar
Rep Power: 9 |
I am trying to define this scheme variable (rp-var-define ’htc 2000.0 ’real #f) in Matlab 2018b as follows in order to assign new value to a variable in an interpreted udf file-
str = ["(re-var-define 'htc 2000.0' real #f)"]; iFluentTuiInterpreter.doMenuCommandToString(str); but its shows this error- Warning: Objects of AAS_CORBA/_ICoFluentUnitStub class exist - not clearing java Java exception occurred: AAS_CORBA.EFluentGenericError: IDL:AAS_CORBA/EFluentGenericError:1.0 at AAS_CORBA.EFluentGenericErrorHelper.read(EFluentGe nericErrorHelper.java:80) at AAS_CORBA._ICoFluentSchemeControllerStub.doMenuCom mandToString(_ICoFluentSchemeControllerStub.java:1 26) I have tried all possible combinations for 'str' variable but nothing worked. I am using Fluent 2020 R1 version. Can someone please help? TIA. Last edited by ATIKADAR; July 16, 2021 at 18:45. |
July 16, 2021, 18:46 |
Amitav tikadar
Rep Power: 9 |
I have solved the issue. Thanks.
October 10, 2022, 04:57 |
ZhangJiming
fluent, fluent - udf |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 13:16 |
Fluent in Batch mode: How to repeat process? | h0rst | FLUENT | 1 | July 5, 2019 13:32 |
How to set as input parameter in Fluent a variable existing outside it? | didimad | FLUENT | 1 | March 3, 2015 12:10 |
modify a intern variable of Fluent with scheme and UDF | fanch33 | Fluent UDF and Scheme Programming | 3 | March 2, 2015 12:01 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 19:58 |
