temperature store and monitoring UDF
Old   July 7, 2021, 04:53
Smile temperature store and monitoring UDF
jangsujin
indsujin is on a distinguished road
Hello
Currently, I'm try UDF to use mesh morpher & optimizer functionality in ansys fluent.
It is also a problem to apply UDF to mmo, but I would like to ask for help because the previous steps are blocked.
I've been referring to C++, UDF Tutorial, CFD Forum for a long time, and I don't see the answer. Please let me know.
Thank you in advance.
What I want to do with mmo is 'Optimization according to surface temperature'.
The key is to get the temperature for each time step and apply it to the system, and to design optimization using mesh morpher&optimizer function based on the temperature received.
Therefore, it is important to get the temperature per time step and store it in the system, and to implement this feature, we are first planning the following UDF code:
1. Use the UDMI function to store the temperature of each time step on the system.
2. Store face information (wafer surface) - temperature (temperature information matched at each face point) of each time step as a .txt file
In fact, only number 1 is needed to apply to mmo, but number 2 is also being used to see if the function is working properly.
My code is like this.
#include "udf.h"
#include "math.h"
#include "mem.h"
#define ID 3
real tem;
real value;
DEFINE_EXECUTE_AT_END(wall_temp)
#if !RP_HOST
face_t f;
Domain *domain = Get_Domain(ROOT_DOMAIN_ID);
Thread *t = Lookup_Thread(domain, ID);
begin_f_loop(f, t)
tem = F_T(f, t);
value = tem;
F_UDMI(f, t, 0) = value;
F_UDMI(F_C0(f, t), t->t0, 0) = value;
end_f_loop(f, t);
#endif
FILE* fptemp = NULL;
DEFINE_EXECUTE_AT_END(write_temp_to_file)
#if !RP_HOST
face_t f;
real time;
int cnt;
char header[16];
if (!fptemp)
fptemp = fopen("temp-vs-time.txt", "w");
fprintf(fptemp, "%16s", "time");
for (cnt = 0; cnt < t->nelements; ++cnt)
sprintf(header, "face%03d", cnt);
fprintf(fptemp, "%16s", header);
fprintf(fptemp, "\n");
time = CURRENT_TIME;
fprintf(fptemp, "%16.5e", time);
begin_f_loop(f, t)
tem = F_T(f, t);
value = tem;
fprintf(fptemp, "%16.5e", value);
end_f_loop(f, t);
fflush(fptemp);
#endif
The number 2 I want is as follows.
(information)
Time step size : 0.05
Number of time step : 100 (total flow time : 6 sec)
Number of mesh :
Number of partition : 16
print :
Current flow time : 0.00 sec
face001 face002 face003 face003 … … faceNNNN(para
3.20e+02(matching at face) 3.20e+2 … … 3.20e+02
Current flow time : 0.05 sec
3.195e+02 3.187e+02 … … 3.196e+02
Current flow time : 0.10 sec
3.193e+02 3.185e+02 … … 3.192e+02
Current flow time : 6.00 sec
2.783e+02 2.781e+02 … … 2.782e+02
However, the output is currently like this.
face000 face001 face002 face003 face004
face1136 face1137 face1138
0.00000e+00
face1140 face1141 face1142 face1143 face1144
face2160 face2161 face2162
0.00000e+00
Could you tell me how to fix the code in order to implement number 1 and 2 properly?
i appreciate your help.
have a good day.
thank you.
The data I referred to.
Monitoring UDF?
indsujin is offline   Reply With Quote
Old   July 9, 2021, 05:08
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
try this code
#include "udf.h"
#include "math.h"
#include "mem.h"
#define ID 3
real tem;
real value;
#if !RP_HOST
face_t f;
begin_f_loop(f, t)
tem = F_T(f, t);
value = tem;
C_UDMI(F_C0(f, t), t->t0, 0) = value;
end_f_loop(f, t);
#endif
#if RP_HOST
face_t f;
real time;
int cnt;
char header[16];
if (!fptemp)
begin_f_loop(f, t)
tem = F_T(f, t);
value = tem;
end_f_loop(f, t);
fflush(fptemp);
#endif
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
mesh morpher&oprimizer, mmo, monitor, stored data, udf
how to store UDF output for arbitrary/particular cell athalia FLUENT 1 September 24, 2019 06:02
Monitoring UDF? Oula Fluent UDF and Scheme Programming 7 December 14, 2018 10:20
monitoring variables Veera Siemens 1 February 12, 2001 18:19
