UDF to track the interface in VOF method in Ansys Fluent
Old   July 6, 2021, 06:02
Default UDF to track the interface in VOF method in Ansys Fluent
radin hosseini
radin_85 is on a distinguished road
I want to write a UDF to track the interface (in VOF model) on a boundary and find the location of the interface on that boundary at each timestep. I have developed the following code:
DEFINE_EXECUTE_AT_END(Interface_tracker)
Domain *d;
face_t f;
FILE *fp;
d = Get_Domain(1);
int zone_ID = 6;
Thread *t = Lookup_Thread(d,zone_ID);
real FC[2];
real ti = CURRENT_TIME;
real alpha;
begin_f_loop(f,t)
F_CENTROID(FC,f,t);
alpha = C_VOF(f,t);
if(alpha == 0.5)
fprintf(fp,"f%d %g %g %g\n", ti, FC[0], FC[1]);
end_c_loop(f,t)
when I am interpreting it I face the following error:
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 19: parse error.
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 20: parse error.
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 22: parse error.
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 23: parse error.
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 24: parse error.
Error: C:/Users/radin/AppData/Local/Temp/interfacetracker.txt.28068.0.c: line 26: t: undeclared variable
Can anyone tell me where is my mistake??
all the best
radin_85 is offline   Reply With Quote
Old   July 6, 2021, 12:31
pakk will become famous soon enough
Can you tell which line is line 19 in your code?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   July 6, 2021, 14:33
radin hosseini
int zone_ID = 6;
Old   July 6, 2021, 17:11
Possible mistake: you declared a variable after assigning a variable. In older dialects of c, that is not allowed.
This is a declaration:
int zone_ID = 6;
This is an assignment:
d = Get_Domain(1);
The problem might thus be that all declarations should be done first. Try to move this assignment down (below the last declaration of alpha as real).
You would make it much easier for yourself if you would compile: you get better error messages.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 15:45
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
How to apply heat flux at the interface when using VOF method? princekar FLUENT 0 November 15, 2015 08:47
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
