Fluent crashes on running simulation.
Old   July 2, 2021, 03:38
Default Fluent crashes on running simulation.
Cooper24 is on a distinguished road
Hello all!! I am new to writing UDFs and am trying to model Selective Laser Melting making use of UDF for moving laser as a source term in the energy equation. I am using volume of fluid for this. I have written a UDF for this. The UDF compiles without any error and initializes also without any error. It's just that when I try to run the simulation, FLUENT crashes. I have attached the equation which I am trying to add as a source term, the screenshot of the error and my UDF also. I think there is some issue with the DEFINE_ADJUST which I am using to get gradient of volume fraction.
I request you all to please help me. I would be really grateful as I am facing a lot of difficulty and running out of time.
Thanks in advance.
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "math.h"
#include "flow.h"
#include "unsteady.h"
#include "metric.h"
#define A 0.4 // Absorption coefficient
#define P 200 // Laser power
#define R 80e-6 // spot radius
#define v 0.1 // scan speed of laser
#define h 25 // Heat transfer coefficient
#define Ta 298 // Ambient air temperature
#define s 5.67e-8 // Stefan Boltzmann constant
#define e 0.5 // Emmisivity
#define Pi 3.1415926535
#define Ts 1658 // Solidus temperature
#define Tl 1723 // Liquidus temperature
#define x0 100e-6 // Initial x position of the laser
#define y0 0.0 // Intiial y position of the laser
#define domain_ID 3 // Domain ID of metal substrate
DEFINE_INIT(volume_fraction, mixture_domain)
int phase_domain_index = 1;
cell_t c;
Thread *t;
Domain *subdomain;
real xc[ND_ND];
sub_domain_loop(subdomain, mixture_domain, phase_domain_index)
if(DOMAIN_ID(subdomain) == 3)
thread_loop_c(t,subdomain)
begin_c_loop_all(c,t)
C_CENTROID(xc,c,t);
if(xc[0] > -0.5e-3 && xc[0] < 0.5e-3 && xc[1] > -0.25e-3 && xc[1] < 0.25e-3 && xc[2] < 0 && xc[2] > -0.3e-3)
C_VOF(c,t) = 1.0;
else
C_VOF(c,t) = 0.0;
end_c_loop_all(c,t)
DEFINE_ADJUST(adjust_gradient, mixture_domain)
Thread *t;
cell_t c;
Domain *subdomain = DOMAIN_SUB_DOMAIN(mixture_domain,phase_domain_inde x);
thread_loop_c(t, subdomain)
begin_c_loop(c,t)
C_UDSI(c,t,0) = C_VOF(c,t);
C_UDMI(c,t,1) = C_UDSI_G(c,t,0)[0];
C_UDMI(c,t,2) = C_UDSI_G(c,t,0)[1];
C_UDMI(c,t,3) = C_UDSI_G(c,t,0)[2];
C_UDMI(c,t,4) = sqrt(C_UDMI(c,t,1)*C_UDMI(c,t,1) + C_UDMI(c,t,2)*C_UDMI(c,t,2) + C_UDMI(c,t,3)*C_UDMI(c,t,3));
end_c_loop(c,t)
DEFINE_SOURCE(heat_source, c, t, dS, eqn) // The name of the UDF is heat_source
Thread *pri_th;
Thread *sec_th;
real source;
real x[ND_ND], time; // Define face centroid vector, distance, time, exponential for laser and volume to get cell volume
time = RP_Get_Real("flow-time"); // Acquire time from Fluent solver
C_CENTROID(x, c, t); // Acquire the cell centroid location
real T = C_T(c,t);
pri_th = THREAD_SUB_THREAD(t, 0);
sec_th = THREAD_SUB_THREAD(t, 1);
if(C_VOF(c,t)>0.05 && C_VOF(c,t)<1)
source = (((2*A*P)/(Pi*R*R))*exp((-2*(pow(x[0]-x0-v*time,2.0) + pow(x[1]-y0,2.0)))/(R*R)) - h*(T-Ta) - s*e*(pow(T,4) - pow(Ta,4)))*C_UDMI(c,t,4);
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
Cooper24 is offline   Reply With Quote
Old   July 2, 2021, 05:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I've received an error while compiling your code,
try to use following
Thread *pri_th;
Thread *sec_th;
real source;
real x[ND_ND], time, T; // Define face centroid vector, distance, time, exponential for laser and volume to get cell volume
T = C_T(c,t);
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 2, 2021, 05:42
Thanks for your reply. Actually I want to multiply tha heat equation term with magnitude of gradient of volume of fraction, as you can see in the attached image in which equation is shown. That is why I have used UDMI for storing the gradient and magnitude of gradient. When I am compiling, it compiles without any error. FLUENT just crashes when I run the simulation. Can you tell if it is the right way to use and multiply with volume fraction gradient??
Thanks
sifsegv, udf, volume of fluid
Fluent running increadibly slow MayTheFlowBeWithYou FLUENT 12 May 22, 2018 03:04
Error while running a Fluent Simulation in Hpc cluster averageindianjoe FLUENT 0 February 7, 2017 06:10
Having problems running transient fluent simulation in batch mode obylong FLUENT 1 August 15, 2014 00:58
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
