HELP!!! UDF code of nonlinear turbulence model |
June 29, 2021, 15:43 |
Omer
Rep Power: 5 |
I want to write UDF of nonlinear turbulence model in fluent. Can you help me about that? I tried but it doesn't work. Would you mind sharing me UDF code for nonlinear turbulence model? Thanks |
June 30, 2021, 01:46 |
Rep Power: 27 |
If you share your attempt, and tell us what the result was (more detailed than that it did not work), we can help to improve it.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 12:50 |
Nonlinear turbulence model NonlinearShih | Thomas Baumann | OpenFOAM | 15 | May 10, 2018 22:43 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 11:29 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
open source code of k-e turbulence model. | karuna | Main CFD Forum | 1 | June 4, 2006 11:09 |
