Osi udf
Like Tree2Likes
Old   June 24, 2021, 13:13
Default Osi udf
Ali reza
1988 is on a distinguished road
Hi
I found this UDF online (I am not very familiar with UDF coding) and I used it to calculate OSI. I am using ANSYS-Fluent 2021.
I used 5 memories for the UDM and run the simulation. All the values out of these UDMs are zero. Any suggestions?
	Oscillatory shear index
#include "udf.h"
#include "math.h"
#include "storage.h"
#include "sg_udms.h"
#define domain_ID 1
#define zone_ID 1
/* Initialize the UDM value to zero in complete domain */
DEFINE_INIT(meminit,domain)
	Thread *c_thread;
	cell_t c;
	thread_loop_c(c_thread,domain)
		begin_c_loop(c, c_thread)
			C_UDMI(c,c_thread,0)= 0;
			C_UDMI(c,c_thread,1)= 0;
			C_UDMI(c,c_thread,2)= 0;
			C_UDMI(c,c_thread,3)= 0;
			C_UDMI(c,c_thread,4)= 0;
		end_c_loop(c, c_thread)
/* Calculate wall shear stress and store them in UDM */
DEFINE_EXECUTE_AT_END(OSI)
	Domain *domain;
	real area;
	face_t f;
	real A[ND_ND];
	cell_t c, c0;
	Thread *t,*t0, *c_thread;
	real wallshear [ND_ND];
	domain = Get_Domain(domain_ID);
	t = Lookup_Thread(domain,zone_ID);
	begin_f_loop(f, t)
		F_AREA(A,f,t);
		area = NV_MAG(A);
		NV_V(wallshear,=,F_STORAGE_R_N3V(f,t, SV_WALL_SHEAR));
		c0 = F_C0(f,t);
		t0 = THREAD_T0(t);
		C_UDMI(c0,t0,0) = NV_MAG(wallshear)/area;
		C_UDMI(c0,t0,1) = -wallshear[0]/area;
		C_UDMI(c0,t0,2) = -wallshear[1]/area;
		C_UDMI(c0,t0,3) = -wallshear[2]/area;
		C_UDMI(c0,t0,4) = (1.-sqrt(C_UDMI(c0,t0,1)*C_UDMI(c0,t0,1) + C_UDMI(c0,t0,2)*C_UDMI(c0,t0,2) + C_UDMI(c0,t0,3)*C_UDMI(c0,t0,3))/C_UDMI(c0,t0,0))/2;
	end_f_loop(f,t)
1988 is offline   Reply With Quote
Old   June 24, 2021, 14:12
pakk will become famous soon enough
Maybe you did not hook the execute_at_end?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   June 24, 2021, 16:36
Ali reza
Thank you for the response. Is it a line or something that I am missing in the code or you mean running the CFD and having the UDF compiled? I compiled it with no error and ran the CFD simulation with no problem.
Old   June 25, 2021, 01:34
After compiling the UDF, you have to tell Fluent to use it. This is called hooking. Look in the manual, it is explained below every example of a UDF.
Old   June 25, 2021, 01:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
compile UDF
load compiled library (in console you will see the list of available functions, you've loaded)
in interface:
user defined-> function hooks ->
initialization -> choose you function -> ok
execute at end -> choose you function -> ok
->ok
1988 and aerosuraj1 like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 23, 2022, 01:45
Default Compilation warning
Md Asif Equbal
mep20108@tezu.ac.in is on a distinguished road
After compilation of UDF, one warning is generated on console screen.
'unsigned long' [-Wint-to-void-pointer-cast]
return ( (void * POINTER_32) (unsigned long) (UNLONG_PTR) P);
I want to know where is the problem. If anyone help it must be appreciated.
Thanks in advance.
mep20108@tezu.ac.in is offline   Reply With Quote
Old   August 23, 2022, 04:07
Alexander
in case you need help you should provide the whole information:
full log output
warnings usually don't lead to problems with running the code
best regards
Old   August 24, 2022, 14:53
Md Asif Equbal
Dear AlexanderZ,
After compilation and hooking the UDF when I start the simulation the fluent exits without showing any error. Try so many times but not succeeded. I am using Ansys 2022R1. Can anyone help what is the actual problem. Here is the screenshot of the Fluent.
Old   October 24, 2022, 01:41
shima mohammadi
sara9310 is on a distinguished road
Originally Posted by mep20108@tezu.ac.in View Post
Dear AlexanderZ,
Did you find the solution to the problem? I have similar problem.
sara9310 is offline   Reply With Quote
Old   October 24, 2022, 07:01
Md Asif Equbal
Dear shima,
First you set user defined memory (UDM).
In this case it is 5. Make sure you have also changed zone Id as per your boundary where you want apply OSI.
After that you can go for hooking.
I did in similar way it solved my problem.
Hope it works for you too.
Old   October 24, 2022, 08:38
shima mohammadi
Dear shima,
Thank you!
I set the number of memories
But Where is the "Zone id" in fluent?
And exactly what should i do?
Old   October 31, 2022, 02:46
Suraj Shembekar
aerosuraj1 is on a distinguished road
zone id for each component, you can see it in the boundary condition
aerosuraj1 is offline   Reply With Quote
Old   October 31, 2022, 03:50
shima mohammadi
How can i enter "zone id" in osi code?
Old   November 1, 2022, 05:44
Suraj Shembekar
you need to edit the UDF file.
you can use a platform like ''visual studio'' or ''geany''
Old   November 1, 2022, 12:34
shima mohammadi
Thank you
I wrote
real zone_ID = 21;
But when i complie udf; 2 error is showing:
1) missing ';' before constant
2) 'real' : illegal use of this type as an expression
How can i solve these problems?!
Old   November 2, 2022, 00:24
Suraj Shembekar
Thank you
I wrote
real zone_ID = 21;
can you post your UDF code here, so that the expert members take a look and suggest any changes.
Old   November 2, 2022, 01:49
shima mohammadi
Thank you
I upload udf file. When I compile this udf, for two line:
real domain_ID=1;
real zone_ID=21;
These errors appear:
Old   November 2, 2022, 02:07
Suraj Shembekar
Thank you
real domain_ID=1;
real zone_ID=21;
Dear Shima,
delete line numbers 54 (real domain_ID = 1 and 55 (real zone_ID = ? from your UDF code and try to run it.
I am quite sure this time you will run it successfully.
All the best
Old   November 2, 2022, 03:51
shima mohammadi
Dear Shima,
All the best
I complied code without these two lines and run it; when I select "osi" in contours of cfd-post, anything is showing!
Some body tell me zone id should specify in code; how can I solve this problem?
Old   November 2, 2022, 06:01
Suraj Shembekar
I am glad that you have successfully compiled and run the simulation.
Yes, the zone ID should be specified in the code for the component on which you would like to see the OSI contours in CFD post. (mostly, people use to see the OSI contours on the "wall", so the zone ID of the wall should be specified within the code).
ansys-fluent, osi, udf
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
can anyone help me about the udf of dynamic contact angle in FLUENT? Albert Lee FLUENT 0 July 1, 2018 09:21
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
