How to deinfe number of particle streams in an injection init udf?
Old   June 1, 2021, 07:26
Default How to deinfe number of particle streams in an injection init udf?
wuyu
seasoul is on a distinguished road
I am trying to define a udf for surface injection and I think it would be using
DEFINE_DPM_INJECTION_INIT
, and a minimal test as below works, by simply defining the particle diameter and flow rate.
DEFINE_DPM_INJECTION_INIT(SURFINJ, I)
Particle *p;
face_t f;
Thread *cthread;
loop(p,I->p)
      P_DIAM(p) = 1e-5;
      P_FLOW_RATE(p) = 1.5e-3;
I have found that the number of streams is the number of faces of the boundary surface, exactly the same as when we define the injection by surface without udf. But if I want to define the number of the streams, for example, twice of the number of the faces and then define the location for each stream, which function should I call?
Thank you in advance.
seasoul is offline   Reply With Quote
[Other] Equal decomposition of cylindrical fluid domain Sean95 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2019 04:34
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
