XY plot at avery time step
Old   May 25, 2021, 11:01
Default XY plot at avery time step
Agore is on a distinguished road
Hi, is there a way to save xy plot data at every time step in a transient simulation?
Agore is offline   Reply With Quote
Old   May 25, 2021, 23:30
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
1. make a monitor which will provide you with the same output data
2. you may execute TUI command after each timestep to write xy plot:
this code will write y-coordinate from surface with id 3 to file called my_plot_at_time_*** with current time
(ti-menu-load-string (format #f "plot solution-set plot-to-file \"my_plot_at_time_~a" (rpgetvar 'flow-time)))
(ti-menu-load-string (format #f "plot solution y-coordinate yes () 3 ()"))
this is TUI commands, which you can modify according to your needs
to execute it after each timestep to go
calculation activities -> execute commands -> new -> define 1 command -> activate -> set to execute on each time step -> put code -> OK
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
