Viscosity error
Old   May 23, 2021, 16:55
Default Viscosity error
Select
MaskOf is on a distinguished road
I am trying to write a UDF that accounts for a viscosity but I keep facing this error.
MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started.
I used fluent 19.2 and fluent 20R2 both gave the same error
MaskOf is offline   Reply With Quote
Old   May 24, 2021, 02:53
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
most likely you have a problem with UDF
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 18, 2022, 06:51
Smile
Telangana
Abhijeeth is on a distinguished road
Please share the solution to the problem as u might have got the solution to the problem already.
Thanks in advance
Abhijeeth is offline   Reply With Quote
centroid, viscosity udf
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
