what is the POLLUT->fluct.temp macro at the non-premixed combustion model?
Old   May 12, 2021, 13:24
Default what is the POLLUT->fluct.temp macro at the non-premixed combustion model?
JongminPark
albert0413 is on a distinguished road
Hi.
I want to solve the NO production rate applied turbulence pdf mode at the non-premixed combustion model for using user-defined function code.
As you know, NO production rate is determined by temperature and species.
I want to set mixture fraction pdf mode in NOx model - turbulence interaction mode tab, So it is need to input the temperature and species considering fluctuating in udf("Pollut->fluct.temp", "Pollut->fluct.yi[spi]"), not average value(Pollut->temp_m, Molecon(Pollut, spi).
When I check the value of Pollut->fluct.temp and Pollut->fluct.yi[spi], there are lots of value at each cell. The difference between two macros, Pollut-> fluct.temp and Pollut->temp_m is confusing..
What is the meaning of "Pollut->fluct.temp" and "Pollut->fluct.yi[spi]"?
albert0413 is offline   Reply With Quote
mixture fraction, non-premixed combustion, nox model, turbulence pdf mode
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
Combustion Model - Laminar Flamelet Model spg1g14 CFX 0 August 5, 2015 19:13
Premixed combustion model - help! HeKhalil ANSYS 0 November 22, 2012 06:39
Turbulent premixed combustion error... XiFoam model achinta OpenFOAM 1 June 23, 2010 06:45
