How to use udf to write the gradient ,nabla and laplacian mathematial conventions? |
May 11, 2021, 09:58 |
WANG LU
Rep Power: 7 |
Hi, every one,
I need to write a new uds transport equation.And now,I was stuck by a question that I do not know how to compile the gradient,nabla,laplacian mathematial conventions.I need to add a source term as the attached picture show. Thank you for your help. Best wishes! |
May 11, 2021, 11:35 |
Rep Power: 27 |
Can you type the equation, your picture is unreadable.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
May 11, 2021, 22:12 |
WANG LU
Rep Power: 7 |
fluent - udf, source code, uds equation |
Third order derivative: Gradient of laplacian | hrushi.397 | OpenFOAM Running, Solving & CFD | 1 | April 17, 2024 13:59 |
Why Laplacian is used instead of a combination of divergence and gradient operators? | HakikiCanakkaleli | OpenFOAM Programming & Development | 3 | September 26, 2019 08:40 |
Write function in Laplacian Foam | mvee | OpenFOAM Running, Solving & CFD | 3 | March 9, 2018 04:22 |
UDF for the Laplacian of chemical concentration | geauxtigers | Fluent UDF and Scheme Programming | 0 | April 7, 2014 19:03 |
gradient or laplacian of an unstructured field | sawyer86 | OpenFOAM Post-Processing | 0 | March 13, 2014 12:40 |
