Help save report file using batch file
Old   March 23, 2021, 09:54
Default Help save report file using batch file
bogate is on a distinguished road
Hello I am running a case using the following batch file
file read-case fluent.cas.h5
file read-dat fluent.dat.h5
file auto-save root-name fluent.cas.h5
solve dual-time-iterate 2400 20
file write-case fluent.cas.h5
file write-data fluent.dat.h5
After opening the finished case I noticed only the default residual monitor was saved. None of the custom report plots, report definitions or report-file were saved.
What do I need to change in the batch file to save the report file which includes all my custom report definitions in order to be able to plot them?
Thanks a lot!
bogate is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
