March 17, 2021, 04:51 |
udf.h file
Rep Power: 6 |
Dear all,
Would anyone be able to provide the udf.h file to me? The udf.h file is in the following folder: path\ANSYS Inc\v120\fluent\fluent12.0.x\src\ where "path" is the folder in which you have installed ANSYS FLUENT. https://www.afs.enea.it/project/nept.../udf/node8.htm I have a UDF source code that I want to use on another CFD platform but I do not have the FLUENT udf.h file which contains the macros definitions and functions. Please reply to this post and I could provide my email. Thank you very much! mnws |
March 17, 2021, 06:01 |
Rep Power: 27 |
What is "another CFD platform"?
Different software? A different computer? I ask this because you are asking a very strange question. To use a UDF, you need Fluent, and if you have Fluent, you have udf.h... So I don't understand your situation.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". Last edited by pakk; March 17, 2021 at 07:16. |
March 17, 2021, 20:45 |
Rep Power: 6 |
Star-ccm+.
I wanted to take a look at udf.h to see if i could use it on star-ccm+. I'm new to the concept of using udf, thought I could cannibalize fluent's udf.h and .c files or write a similar code for use on star-ccm+. I wanted to ascertain if udf.h could be used outside of fluent. I guess not. Thank you for the reply! |
March 18, 2021, 04:21 |
Rep Power: 27 |
Your guess is correct: it is useless to have udf.h in Star.
But it was worth asking!
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
