Parallel temperature prandtl udf
Old   March 9, 2021, 10:49
Default Parallel temperature prandtl udf
Gaurav Kumar
gauravkmr is on a distinguished road
How can I parallelize the following temperature prandtl number udf??
/* Specifying a Constant Temperature Prandtl Number */
#include "udf.h" DEFINE_PRANDTL_T(user_pr_t,c,t)
real pr_t;
pr_t = 0.25;
return pr_t;
gauravkmr is offline   Reply With Quote
Old   March 9, 2021, 15:42
pakk will become famous soon enough
There is nothing to parallelise here... Just use it.
pakk is offline   Reply With Quote
Old   March 9, 2021, 15:48
Gaurav Kumar
Thanks for your answer, but when I compile it in fluent, it shows error, that the code is not for parallel use.
Old   March 10, 2021, 03:08
Can you copy that error? I've never seen that one before when you compile...
Old   March 10, 2021, 03:10
And I assumed you had it working for serial, is that correct?
Old   March 10, 2021, 03:14
Gaurav Kumar
Following is the error:
The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
I had not worked it for serial, I just wrote the script and compiled then it shows the above error.
Old   March 10, 2021, 09:30
This is not the error you get when you compile. This is the error you get when you try to load. (Read it!)
Show the error that you get after you click "build".
Old   March 10, 2021, 09:32
Oh, I hope that you did not really put
literally as one line... In all the examples in the manual, this is split into two lines:
#include "udf.h"
If you put this as one line, it will probably not compile, and the compiler should have given you an error in line 1...
Old   March 11, 2021, 03:10
Gaurav Kumar
I had split into two lines and wrote in notepad and saved in .c format.
Old   March 11, 2021, 03:51
Gaurav Kumar
When I click build then TUI shows the below message.
Copied E:\Projects\Gaurav\Simulation\18\pr2.c to libudf45\src
Creating user_nt.udf file for 3ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v201\fluent"\fluent20.1.0\sr c\udf\makefile_nt.udf "libudf45\win64\3ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf45")(chdir "win64\3ddp_host")'nmake' is not recognized as an internal or external command,
operable program or batch file.
Creating user_nt.udf file for 3ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v201\fluent"\fluent20.1.0\sr c\udf\makefile_nt.udf "libudf45\win64\3ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf45")(chdir "win64\3ddp_node")'nmake' is not recognized as an internal or external command,
Done.
Old   March 11, 2021, 04:24
This is your error.
Search for this text on this forum. It is a Fluent installation / configuration problem, it has nothing to do with your code. Your code is not even read. I am no expert on how to solve that.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
Old   March 11, 2021, 06:36
Gaurav Kumar
Many many thanks for your concern on this thread.
Thanks again.
Inlet temperature as a function of outlet temperature UDF wimblo Fluent UDF and Scheme Programming 5 November 25, 2021 07:06
problem in temperature and liquid fraction value in the udf durg FLUENT 0 October 23, 2018 02:52
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
Parallel UDF Segmentation fault error KevinZ09 Fluent UDF and Scheme Programming 1 January 9, 2017 06:30
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
