March 14, 2021, 01:43 |
#21 |
Rep Power: 5 |
Thanks for your reply but I have already solved that part.
March 14, 2021, 01:44 |
#22 |
Rep Power: 5 |
Thanks for your reply but I have already corrected that part.
March 14, 2021, 01:47 |
#23 |
Rep Power: 5 |
Right now I think I have solved that nmake error. Now whenever I build and load the file I am getting following messages :
https://imgur.com/shobqf9 |
March 14, 2021, 02:55 |
Define mass source on boundary cells used UDF
#24 |
ssetay
Rep Power: 6 |
Hi, friends
I am using UDF to define a mass source on the boundary cells, here's my code. My case is this: particles and water flow in a pipe, and I want to define a mass source for the particle phase in the pipe wall cells. When I compile this UDF, it works normally, but the volume fraction of particles at the wall has not changed. According to my UDF, the volume fraction of the particle phase in the pipe wall cells should be reduced. I don't know where the error is, but the UDF can work well after compilation. Can anyone help me? //* You are storing source in User defined memory under DEFINE_ON_DEMAND. Then you are using UDMI(c0,t0,0) in DEFINE_SOURCE *// #include "udf.h" //get the boundary cells DEFINE_ON_DEMAND(selecting_the_cells) { #if !RP_HOST Domain *d; Thread *t, *tc, *t0; face_t f; cell_t c, c0; d = Get_Domain(1); tc = Lookup_Thread(d, 9); //Get boundary thread, wall zone ID is 9 //Loop through all the cell threads in the domain thread_loop_c(t, d) { //Loop through the cells in each cell thread begin_c_loop(c, t) { C_UDMI(c, t, 0) = 0; } end_c_loop(c, t) } begin_f_loop(f, tc) { c0 = F_C0(f, tc); t0 = THREAD_T0(tc); C_UDMI(c0, t0, 0) = 1; } end_f_loop(f, tc) #endif } DEFINE_SOURCE(mass_source, c, t, dS, eqn) { real source; if (C_UDMI(c, t, 0) > 0.) { source = -1000.; dS[eqn] = 0.; } else { source = 0.; dS[eqn] = 0.; } return source; } |
March 14, 2021, 05:23 |
#25 |
Rep Power: 27 |
You forgot to tell what kind of variable d is.
Domain *d; (if I remember correctly)
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
March 14, 2021, 07:00 |
#26 |
Rep Power: 5 |
It is the variable which is used to get the domain in DEFINE_ON_DEMAND macro.
March 14, 2021, 07:20 |
#27 |
Rep Power: 27 |
Yes I know that, but you did not tell Fluent, so you have to add that code.
March 14, 2021, 09:42 |
#28 |
Yasser Selima
Rep Power: 19 |
Look in your photo ... the error is coming from the 4 lines above "Done"
March 15, 2021, 01:04 |
#29 |
Rep Power: 5 |
I have solved this error and it is working perfectly. Thank you for all of your help. This is the final code.
#include "udf.h" DEFINE_ADJUST(tempgrad,d) { Thread *t; cell_t c; face_t f; thread_loop_c(t, d) { begin_c_loop(c,t) { C_UDSI(c,t,0)=NV_MAG(C_T_G(c,t)); } end_c_loop(c,t) } } DEFINE_ON_DEMAND(store_gradient) { Domain *d; d = Get_Domain(1); cell_t c; Thread *t; thread_loop_c (t,d) { begin_c_loop (c,t) { C_UDMI(c,t,0) = NV_MAG(C_UDSI_G(c,t,0)); } end_c_loop (c,t) } } |
March 15, 2021, 01:38 |
#30 |
Rep Power: 5 |
UDF is loading and compiling perfectly but I can't seem to find this variable anywhere. Do you know where to look for ?
March 17, 2021, 22:37 |
#31 |
Alexander
Rep Power: 34 |
results -> contours -> contours of: user-defined scalar/user-defined memory -> select surface or zone
best regards ****************************** press LIKE if this message was helpful |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
