Multiple 'Define' macros to be hooked into one location
Old   February 28, 2021, 12:25
Default Multiple 'Define' macros to be hooked into one location
Will Crawford-Jones
wcj1n18 is on a distinguished road
I would like to use both DEFINE_SDOF_PROPERTIES and DEFINE_CG_MOTION for just one SDOF object. Problem is, they should both be hooked into the same location (Dynamic Mesh - Dynamic Mesh Zones - SIX DOF UDF/ Properties). How can I assign a SDOF property and a CG motion to one SDOF object?
So far, I have put both of the DEFINE macros in one .c file and compiled with no problems. Problem is when I go into (Dynamic Mesh - Dynamic Mesh Zones - SIX DOF UDF/ Properties), it gives me the option of assigning one of the DEFINE macros to the object but not both?
Is this not possible or am I missing something here?
Thank you
PS. I have one rather more long-winded back up plan, however, simply doing it as described above would make things easier.
wcj1n18 is offline   Reply With Quote
Old   July 14, 2023, 07:54
Default Solution found?
Debayan Bera
Debayan is on a distinguished road
I'm working on something that involves a similar problem. Were you able to solve this particular problem? If you did then please let me know xx
Debayan is offline   Reply With Quote
Old   April 23, 2024, 13:19
manoron is on a distinguished road
in define_sdof macro, dt_vel_cg option can be used to define motion which is intended in define_cg_motion.
both macro have certain difference.cg_motion imposes the motion which is irrelevant of 6dof equation and associated forces.
manoron is offline   Reply With Quote
cg_motion udf, sdof, sdof_properties
Running multiple macros on windows Rohit4689 STAR-CCM+ 2 February 28, 2019 21:03
Creatin macros for multiple data sets and assigning multiple zones Skyler Tecplot 0 January 24, 2019 13:24
Data access in define macros Magneto Fluent UDF and Scheme Programming 11 July 25, 2012 13:22
Robin B.C. Yu FLUENT 3 May 27, 2012 05:19
How to define the location of domain interface? Freshman CFX 3 June 2, 2005 21:06
