Fluent UDF - How to irreversibly change a material's property once a certain temperat |
February 26, 2021, 06:15 |
Taosif Alam
Rep Power: 6 |
I want to write a Fluent UDF that changes material's property irreversibly once it reaches a certain temperature. Like, if 500 K be my target temperature, at the start of the simulation when the material is below that temperature it will have a density of 1000 kg/m^3. But once the temperature reaches or goes beyond 500 K its density changes to 700 kg/m^3 and stays like that even if in later period temperature falls down below 500K. What algorithm should I follow to write this UDF?
fluent - udf |
Issue on the design change when using the Ansys FLUENT adjoint-based shape optimizer | zyao1 | FLUENT | 0 | December 4, 2020 10:56 |
My UDF works well with Fluent 16 but not with Fluent 19 | Ahmed A. Serageldin | Fluent UDF and Scheme Programming | 3 | October 19, 2018 12:38 |
can anyone help me about the udf of dynamic contact angle in FLUENT? | Albert Lee | FLUENT | 0 | July 1, 2018 09:21 |
UDF interpret in Fluent | wanghaojie | Fluent UDF and Scheme Programming | 1 | February 3, 2012 15:51 |
UDF in Fluent | subha_meter | Main CFD Forum | 0 | October 18, 2009 00:54 |
