Interference of UDF with flow problem solving
Old   February 18, 2021, 18:44
Default Interference of UDF with flow problem solving
etedalgara is on a distinguished road
Hi. I have a dynamic mesh UDF to simulate the blade movement. I want to flow past 1 second time and after that, the UDF applies to solve the problem. all are ok with " if time >1" and the blade never moves until the time become 1 sec. but the flow diverges before time becomes 1 second! there is no movement in the test case. when I run the test case "fixed blade" without compiling the UDF all will be ok and no divergence happened! where is the problem?!
Thanks for your help
etedalgara is offline   Reply With Quote
#cfd, #compiling, #dynamicmesh
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 13:12
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
