velocity slip and temperature jump
Old   January 7, 2021, 04:50
Question velocity slip and temperature jump
zhangdongjie
zhangdongjie is on a distinguished road
I'm simulating a nozzle with rarefied gas. Its kn number is very large. First order slip and temperature jump must be added. I use Maxwell slip equation to write UDF, but I don't know where UDF should be loaded. I look up the data. The sliding speed can be loaded into the shear stress, so where is the temperature jump loaded? Is it loaded directly into the wall temperature? But my wall temperature is fixed at 300K. If anyone has a compiled UDF file, can you send me one? Thank you very much.1248385182@qq.com
zhangdongjie is offline   Reply With Quote
Old   January 7, 2021, 08:05
pakk will become famous soon enough
I hope you are aware of the low-pressure boundary slip option in Fluent. If not, look it up in the manual, it will simplify your problem a lot.
pakk is offline   Reply With Quote
Old   January 8, 2021, 04:38
Talking
zhangdongjie
Thank you very much for your reply. I watched the low pressure boundary slip, which helped me a lot. But it seems that fluent 2D doesn't have the low-pressure boundary slip button, only 3D does. What should I do. In addition, if I use the low-pressure boundary slip to calculate, is it different from UDF?
Old   January 10, 2021, 07:13
A UDF is something that you program. You tell the UDF what yo do. So if you want the UDF to be different, it can be different. If you want it to be the same, it can be the same (with some work).
Velocity slip and temperature jump UDF zhangdongjie FLUENT 1 October 15, 2021 04:17
How to set slip velocity and temperature jump awuunity CFX 10 July 2, 2018 09:40
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Implementation of maxwell slip velocity and Temperature jump with openfoam yassepid OpenFOAM 2 June 28, 2016 08:05
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. dayashankar FLUENT 1 May 18, 2016 22:45
