UDF DEFINE_SPECIFIC_HEAT after loading - fluent closed automatically
Old   December 31, 2020, 06:13
Question UDF DEFINE_SPECIFIC_HEAT after loading - fluent closed automatically
Eva Knahl
EvaKn is on a distinguished road
I have a Problem with a UDF for specific heat.
I can built and load the udf and in the Material Dialog I can choose the udf.
Now when i want to assign the udf, it loads briefly and right after that fluent closes automatically. Why does this happen?
In the UDF I also define density, sound of speed, thermal conductivity and viscosity with DEFINE_PROPERTY - this works perfectly...
How can I fix this? Do I have a Mistake in the UDF?
only the DEFINE_SPECIFIC_HEAT part
eth-cpL.c
Thanks in advance for the help!
EvaKn is offline   Reply With Quote
Old   December 31, 2020, 09:24
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
Attachment 81846
are you using any UDM in your UDF?
rupak504 is offline   Reply With Quote
Old   December 31, 2020, 09:29
Eva Knahl
No, I am not using any UDM.
Old   January 3, 2021, 19:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
remove line
T = C_T(c,t);
from your code, T is defined in header
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
define_specific_heat, fluent closing, fluent parallel, udf
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 09:39
Creating UDF and loading it in ANSYS Fluent singingfish Fluent UDF and Scheme Programming 1 February 7, 2014 13:10
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
