Which macro should I use to define the heat flux of a wall ? DEFINE_HEAT_FLUX or DEF |
December 24, 2020, 13:12 |
Rep Power: 10 |
Which macro should I use to define the heat flux of a wall ? DEFINE_HEAT_FLUX or DEFINE_PROFILE ?
2.3.11. DEFINE_HEAT_FLUX 2.3.11.1. Description You can use DEFINE_HEAT_FLUX to modify the heat flux at a wall. Despite the name, a DEFINE_HEAT_FLUX UDF is not the means to specify the actual heat flux entering a domain from the outside. To specify this type of heat flux, you would simply use a DEFINE_PROFILE function in conjunction with a heat flux thermal boundary condition. In contrast, a DEFINE_HEAT_FLUX UDF allows you to modify the way in which the dependence between the flux entering the domain and the wall and cell temperatures is modeled. |
December 25, 2020, 05:19 |
mostafa_Fx
Rep Power: 5 |
Define_profile
December 25, 2020, 10:27 |
what is the use of DEFINE_HEAT_FLUX ?
Rep Power: 10 |
Heat loss through wall to surroundings, wall Heat flux | Vishnu_bharathi | CFX | 4 | December 20, 2017 19:36 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
wall heat flux in openfoam | hz283 | OpenFOAM | 1 | January 4, 2014 08:51 |
User Wall Heat Flux | Dyls | STAR-CCM+ | 0 | May 13, 2013 12:58 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
