Can any tell me which is right for the below codes?
Old   December 30, 2020, 07:20
pakk will become famous soon enough
Originally Posted by hitzhwan View Post
You mean the below code you load work? Why I have some errors when I load it by the same process, what fluent edition do you use? Would you please send me your case and udf to me, I want to try more, thank you so much .
#include "udf.h"
DEFINE_PROFILE(hf_change,thread,position)
face_t f;
const real heat_flux1 = 0;
const real heat_flux2 = 500;
const real switch time = 0.0001;
const real time = CURRENT_TIME;
const real hf = time<switch_time?heat_flux1:heat_flux2;
begin_f_loop(f,thread)
F_PROFILE(f,thread,position)=hf;
end_f_loop(f,thread)
The hitzhwan of 24 December was able to load this without errors. The hitzhwan of 29 December gets errors. It's very confusing like this.
pakk is offline   Reply With Quote
Old   December 30, 2020, 13:09
Default why to make it solid, not fluid?
  #22
hitzhwan is on a distinguished road
Originally Posted by AlexanderZ View Post
Unfortunately, I'm not able to send you any files.
This is not the problem of version, code is simple and should work in any version.
I recommend you to make new test simple geometry:
rectangular, make it solid, not fluid
make new source file (with other name) and compile it again
load and apply UDF, run transient simulation
most likely, you didn't compile the code
hitzhwan is offline   Reply With Quote
udf
