December 11, 2020, 08:34 |
UDF for reading radiative heat flux
ssa
Rep Power: 7 |
Hi all,
I want to read the radiative heat flux from DO model or the P1 radiation model from the cells. There is a macro BOUNDARY_RAD_HEAT_FLUX(f,tf) for reading the heat flux values from the wall. But I want to read the heat flux from the interior cells. I tried to read the heat flux of interior faces with the BOUNDARY_RAD_HEAT_FLUX and average them to get the heat flux of the cell. But it is working only with the boundary faces and not with the interior faces. Is there any other macro available for reading the heat flux from the interior cells? Thanks. senthil. |
December 14, 2020, 00:53 |
Alexander
Rep Power: 34 |
from my point of view, radiative heat flux is not defined on interior boundary condition. Actually, all faces, where radiative source is calculated are defined while you are preparing model.
best regards ****************************** press LIKE if this message was helpful |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
UDF for a time varying heat flux boundary condition | B.Hamada | Fluent UDF and Scheme Programming | 9 | August 8, 2018 12:51 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
UDF for time dependent heat flux | Rameshwar Ajja | FLUENT | 0 | February 16, 2006 00:26 |
Heat flux UDF problem | Paul | FLUENT | 1 | September 11, 2003 06:13 |
