Moisture Transfer
Old   December 6, 2020, 22:45
Default Moisture Transfer
Abbas Raza
Abbas20000220 is on a distinguished road
I am writing a udf for a defining moisture from Air to Lcl solution. In between two fluid, a membrane(solid) is inserted, Now, I want to define mass fraction just above the membrane first layer of cells. Can any one help me in this matter?
#include "udf.h"
#define Xm 0.0032
DEFINE_PROFILE(mass_x_inlet, thread, face)
Thread *t;
face_t f:
cell_t c:
begin_f_loop(f,thread)
F_CENTROID(x,f,thread)
This is not a complete udf.
This loop will be used for all cell faces in the boundary zone. I just want to specify first layer above the membrane. with what command I can do it?
Seniors please help me.
Thanks in advance.
Regards,
Abbas Raza
Abbas20000220 is offline   Reply With Quote
Old   December 7, 2020, 01:10
pakk will become famous soon enough
Why in the first layer of cells?
Why don't you use the faces of the membrane, with a normal boundary condition?
pakk is offline   Reply With Quote
Old   December 7, 2020, 01:50
Default Moisture Transfer across membrane
Abbas Raza
Actually, I need to make moisture content across the membrane. How I can give command in udf that moisture content in above the cell of membrane.
If i induce moisture at inlet, How I would be able to know that moisture content is just above the cells of membrane? In short, How cell to cell moisture can be modelled with what command?
Thanks in advance.
Regards,
Old   December 7, 2020, 02:44
I'm not talking about setting the moisture on the inlet. I'm talking about setting the moisture on the faces of the membrane.
Old   December 7, 2020, 02:50
Abbas Raza
I was asked by group leader to do so. I am beginner in this field. I need your suggestion how to do this? If I use cell approach what will be consequence? And using face of membrane will be easier?
Thanks in advance!
Regards,
Old   December 7, 2020, 05:47
Thanks in advance!
Regards,
If you use face approach, you just go to the boundary equation in Fluent, and set the "moisture content" to the value that you want, if you want a fixed value. (I don't know how you plan to model moisture content, but it can be a UDM, it can be with species, it does not matter: just set the value that you want.)
if you don't want a fixed value, but want to use an equation, then you need a UDF.
If you use cell approach, you have to use UDF, you might run into stability problems, you might get a big mesh-dependency, you have to write something that only finds cells directly touching the membrane, and in general you make your life complicated for no reason.
Old   December 8, 2020, 03:27
Abbas Raza
Thankyou very much for your response.
I have another query.
I have two fluids. one is Air & other is Licl solution. & I want to insert a PVDF membrane between two. I modelled platein XYplane ( Length, width =100mm) & thickness 2mm in zaxis using extrude option. I select another plane having offset from zaxis 2mm.& draw another plate of having same dimensions. One is modelled as air while other is Licl. Both of them are stacking to each other. In mesh option, I deleted contact region (that automatically made) & named all regions manually like (inlet, outlet, airinterface, liclinterface etc) & meshed by using default method.
In Fluent setup, I used mesh interface, & joining airinterface & liclinterface and named the coupled wall as a mmebrane & its shadow is also formed.
After having a simulation, I am getting a message: Zone surface cannot create from sliding interface zone. creating empty surface zone.
looking forward your kind response for settling the issue.
I used in ansys16 & 20. both have same issue.
Thanks in advance.
Regards
Old   December 9, 2020, 03:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
read log file on the second picture, I can see, you have an error on line 38 of your UDF
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 9, 2020, 03:34
Abbas Raza
Thank you for your response.
This was an attempt for interpreting UDF. However, my prime concern is regarding empty surface zone by using mesh interface. For my case, I am trying to consider this interface of both fluids is acting as a membrane. Fluent post processing isn't helping me in this matter.
I want to know that my approach is wrong or i need to do something else?
Thanks in Advance.
Regards,
ansys 2020, cfd main forum, fluent - udf, mass diffusivity, udf customize
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
