Understanding mathematics of DEFINE_VR_RATE UDF
Old   December 5, 2020, 08:21
Default Understanding mathematics of DEFINE_VR_RATE UDF
Abhishek Goel
abgoel363 is on a distinguished road
I want to understand the mathematics behind the UDF given below, how it is calculating the reaction rate. Specifically, the loop running to calculate ci and prod. what this loop is calculating and why?
Thank you so much for the help in advance.
#include "udf.h"
DEFINE_VR_RATE(vol_reac_rate,c,t,r,wk,yk,rate,rr_t )
real ci, prod;
int i;
/* Calculate Arrhenius reaction rate */
prod = 1.;
for(i = 0; i < r->n_reactants; i++)
ci = C_R(c,t) * yk[r->reactant[i]] / wk[r->reactant[i]];
prod *= pow(ci, r->exp_reactant[i]);
*rate = r->A * exp( - r->E / (UNIVERSAL_GAS_CONSTANT * C_T(c,t))) *
pow(C_T(c,t), r->b) * prod;
*rr_t = *rate;
/* No "return..;" value. */
abgoel363 is offline   Reply With Quote
Old   December 5, 2020, 10:19
pakk will become famous soon enough
What it is calculating: the code has a comment
So, that is probably what it is calculating. It is a loop because every reactant has a different rate.
Why, you also asked. I don't know how to answer it it in a different way than: because the person who wrote this code, needed the result of the calculation.
pakk is offline   Reply With Quote
Old   December 5, 2020, 10:31
Abhishek Goel
Thanks for the reply.
By "what it is calculating", I mean the reason to calculate ci and prod, as Arrhenius equation is defined as
k = A* exp(-E/RT) * T^b
Please explain the meaning and purpose of calculating prod.
Also, what does wk[r->reactant[i] signifies?
Is yk[r->reactant[i] means initial mass fraction of reactants and
r->exp_reactant[i] means rate exponent of the reactants??
Old   December 5, 2020, 15:03
I guess prod is the product of the concentrations, used in the usual reaction rate equations.
But why this UDF? Is it from the manual? Where did you find it?
Old   December 5, 2020, 20:07
Abhishek Goel
Yes, this is the example udf given in the manual for volumetric reaction rate. I have made the changes in it as per my requirement in this code but not able to understand the mathematics of this code by calculating ci and prod. The rest is quite understandable though.
Old   December 6, 2020, 03:52
Then look in the manual. Wk and yk are the fifth and sixth argument of the macro.
Above the example, the arguments are explained. The fifth and sixth are mw and yi. So read what they mean.
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 13 June 23, 2024 14:12
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
UDF programming fullmonty FLUENT 5 June 30, 2011 03:40
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 14:16
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
