Modelling of particle diffusion with particle wall interactions
Old   December 1, 2020, 01:33
Default Modelling of particle diffusion with particle wall interactions
L.A.Isanka
Achini is on a distinguished road
Hello!
I am working on a problem in which nanoparticles diffuse in a channel while having van der waals interactions with the channel wall. should I use the species transport model and use combine a UDF to include particle wall forces,
or can I use a UDF with the DPM model without using the species transport model?
Please suggest a method.
These are polystyrene particles are in a liquid medium.
I am already working on a UDF to include particle wall interactions with DPM model, where particles are given a velocity to flow through the channel.
But instead of that, I need to make particles flow through the channel via diffusion. I want to include a body force to the diffusing particles.
How can I do that?
Thank you!
Achini is offline   Reply With Quote
dpm bodyforce, species model, udf
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Hiting the wall by particle shchepan OpenFOAM Running, Solving & CFD 31 February 4, 2016 06:09
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
