If scheme doesn't work
Old   November 30, 2020, 15:37
Default If scheme doesn't work
p.1
Italia
p.1 is on a distinguished road
Hi, I have write this udf but the if statement seems not work. Someone can help me?
#include "udf.h"
DEFINE_ADJUST(dudy, domain)
Thread *t;
cell_t c;
real xc[ND_ND];
real x;
real y;
thread_loop_c(t, domain)
begin_c_loop(c, t)
C_CENTROID(xc, c, t);
x = xc[0];
y = xc[1];
if(y < 0 && x<6)
C_UDMI(c, t, 0) = -(C_V(c, t)*C_U_G(c, t)[1])
else if(y<0 && x>6)
C_UDMI(c, t, 0) = -(C_V(c, t)*-C_U_G(c, t)[1])
else if(y>0 && x<6)
C_UDMI(c, t, 0) = -(-C_V(c, t)*C_U_G(c, t)[1])
else if(y>0 && x>6)
C_UDMI(c, t, 0) = -(-C_V(c, t)*-C_U_G(c, t)[1])
end_c_loop(c, t)
p.1 is offline   Reply With Quote
Old   November 30, 2020, 22:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how could you know that it doesnt work?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 1, 2020, 03:28
p.1
Italia
Beacuse if I change the x value (for example x<10 or x>10) the results are the same.
Old   December 1, 2020, 03:41
pakk will become famous soon enough
Try this, to see if it works:
Thread *t;
cell_t c;
real xc[ND_ND];
real x;
real y;
begin_c_loop(c, t)
x = xc[0];
y = xc[1];
if(y < 0 && x<6)
C_UDMI(c, t, 0) = 1;
else if(y<0 && x>6)
C_UDMI(c, t, 0) = 2;
else if(y>0 && x<6)
C_UDMI(c, t, 0) = 3;
else if(y>0 && x>6)
C_UDMI(c, t, 0) = 4;
end_c_loop(c, t)
By the way: are you sure you did not get any compile error? Because I think you forgot some semicolons, and the compiler should complain about that.
pakk is offline   Reply With Quote
Old   December 1, 2020, 03:52
p.1
Italia
Thread *t;
cell_t c;
real xc[ND_ND];
real x;
real y;
begin_c_loop(c, t)
x = xc[0];
y = xc[1];
if(y < 0 && x<6)
else if(y<0 && x>6)
else if(y>0 && x<6)
else if(y>0 && x>6)
end_c_loop(c, t)
Thank you, no when I compile the UDF on Fluent there aren't errors.
Where I forgot some semicolons?
Old   December 1, 2020, 13:38
You forgot semicolons where i changed the code, obviously.
You also forgot to show the test result. How does UDM 0 look like if you plot with this UDF?
Old   December 1, 2020, 13:40
And does this give errors?
Thisshouldgiveanerror() ;
Old   December 1, 2020, 13:57
p.1
Italia
It works. Thank you.
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
Problem using Central differencing scheme with LES WALE selvam2487 CFX 8 July 23, 2017 16:33
forward diff scheme vs backward diff scheme zdunol Main CFD Forum 5 November 30, 2015 14:42
RP_Set_Integer does not work in parallel 86lolo Fluent UDF and Scheme Programming 2 July 3, 2014 12:37
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
