how to get temperature at wall
Old   November 26, 2020, 11:34
Default how to get temperature at wall
Tyler Richardson
tricha122 is on a distinguished road
I am putting together a UDF for calculating heat transfer coefficient, and i am having the strangest issue.
It looks like what is retrieved from my F_T(f,t) does not match the wall temperature, wall adjacent temperature, static temperature, or total temperature in my solution (solid pipe with constant heat flux, and fluid flowing through)
Is it expected that F_T(f,t) would grab the wall temperature?
How might i retrieve the wall temperature otherwise?
My code is quite simple:
begin_f_loop(f,t) {
t0=THREAD_T0(t);
c0=F_C0(f,t);
TWadj = F_T(f,t);
C_UDMI(c0,t0,3) = TWadj;
F_UDMI(f,t,3) = TWadj;
} end_f_loop(f,t);
TIA!
tricha122 is offline   Reply With Quote
Old   January 25, 2021, 05:14
Lie Wei
Lie Wei is on a distinguished road
hi, Tyler
I'm having the same problem as you. Have you found a solution?
Lie Wei is offline   Reply With Quote
Old   January 25, 2021, 07:08
Tyler Richardson
Originally Posted by Lie Wei View Post
hi, Tyler
Yes, it turns out in order to get F_T to match your wall temperature, you need to have similar mesh sizing on both sides of the wall. So you need to inflate your solid mesh similar to your fluid mesh.
Old   February 6, 2021, 22:19
Lie Wei
Thanks for your reply. however, there is no solid domain in my simulation. Is there any solution in this case?
f_t, wall temperature
A question related to writing expression for (htc)Heat transfer coefficient Hamda CFX 11 April 17, 2020 01:57
Expert Parameters in CFX-pre ebrahem FLUENT 0 December 20, 2019 03:39
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 02:41
