Udf velocity inlet profile with multiphase mixture (ansys fluent) |
November 23, 2020, 20:12 |
Engineering_Student
We are two undergraduate students seeking for help!!!
We are trying to simulate a laminar flux through a 3D pipe (25 cm long, 2 cm of diameter) consisting of a multiphase flux (air and water). We want to implement a UDF for the velocity inlet consisting of several time-dependent square pulses. In our ideal scenario, the pipe is initially full of air and water is injected from the inlet periodically (every injection is a square pulse) and the amount of water decreases with each interval. To do so, we have written the following code, but it does not seem to work. COULD ANYONE HELP PELASE?? HOW CAN WE SOLVE IT??? THANK YOU VERY MUCH IN ADVANCE! -------------- #include "udf.h DEFINE_PROFILE(inlet_velocity, t, i) { real current_time; face_t f; current_time = CURRENT_TIME; begin_f_loop(f, t) { if ((current_time < 2) | (current_time > 9 & current_time<14) | (current_time > 21 & current_time<25) | (current_time > 32 & current_time<37) | (current_time > 44 & current_time<49)) { F_PROFILE(f, t, i)=0; } else if (current_time >= 2 & current_time<=9) { F_PROFILE(f, t, i)=1*0.08; } else if (current_time >= 14 & current_time<=21) { F_PROFILE(f, t, i)=0.75*0.08; } else if (current_time >= 25 & current_time<=32) { F_PROFILE(f, t, i)=0.5*0.08; } else if (current_time >= 37 & current_time<44) { F_PROFILE(f, t, i)=0.25*0.08; } } end_f_loop(f, t) } |
November 24, 2020, 08:48 |
Gert-Jan
Rep Power: 28 |
Use CFX. No need to use Fortran. Just add a few equations to the simulations and off you go.
December 12, 2020, 02:23 |
Dnyanesh Mirikar
Rep Power: 7 |
Try named expressions feature provided by Ansys and you may end up solving your problem. Let me know if you want any help further.
ansys fluent, multiphase mixture model, udf |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 01:17 |
Ansys Fluent 17 UDF Velocity Profile Update. | Phil-M | Fluent UDF and Scheme Programming | 4 | October 17, 2016 10:05 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
logarithmic velocity profile for velocity inlet in Fluent | amarendernag | FLUENT | 3 | August 25, 2012 06:44 |
