Airfoil Batch Run with UDM export everytime
Old   November 20, 2020, 06:36
Default Airfoil Batch Run with UDM export everytime
syedabdullah's Avatar
Syed Muhammad Abdullah
syedabdullah is on a distinguished road
I am running a particle tracking simulation (on an airfoil) in Fluent that uses a UDF to store in the
user defined memory a number of parameters (angle of collision, velocity etc).
The UDM variables are there in the results section for plotting and i can export them to a file to work with them.
I want to run a batch simulation for a number of angle of attacks (changing inlet veloicty BC) so its a lot of work
Can i do something to automate the process so that the simulation can run for multiple number of AoA, export the UDM variables
to separate files for each simulation and start a new simulation for all AoA of the velocity inlet
syedabdullah is offline   Reply With Quote
Old   November 20, 2020, 08:54
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may define everything in journal file, and execute it
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 20, 2020, 09:13
Can you explain a little bit?
how can i export the udm variables as xy plot files after each simulation of angle of attack
Old   November 21, 2020, 17:08
pakk will become famous soon enough
Find the commands to do what you want to do in the text user interface (TUI).
Once that works, put all these commands in a text file, and that is your journal file.
pakk is offline   Reply With Quote
Fluent export - CFD Post - Airfoil Results Wingman ANSYS 0 November 18, 2016 17:36
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
run time post processing of pressure distribution over airfoil yzf1215 OpenFOAM Post-Processing 1 June 26, 2013 08:01
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
