Is it possible to set equations on/off with UDF while solving?
Old   November 11, 2020, 11:05
Default Is it possible to set equations on/off with UDF while solving?
Deutschland
schwaral is on a distinguished road
Send a message via ICQ to schwaral Send a message via AIM to schwaral Send a message via Yahoo to schwaral
Hi all,
I would like to solve a problem of two UDS uncoupled since due to coupling the solving time is way too long. Is there a possibility to solve UDS1 for one timestep and then turn of UDS1 and solve for the 2nd timestep UDS2 by using a define adjust UDF?
Or is the only way to use a journal file and set simulation time equal one timestep and change the equations after the whole simulation is finished after one timestep? It would be nice to have a way to set the simulation time larger then one timestep.
Alex
schwaral is offline   Reply With Quote
Old   November 12, 2020, 04:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you need journal file for that
run 1 time step simulation several times, to make it longer
you may use scheme language inside journals
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 12, 2020, 06:34
Deutschland
thanks a lot!
Yep I sorted it out like that. You helped me quite a lot in my thesis! Could you maybe help me with this problem in the forum for one last time? It is the last step before my setup is finished. Ansys support does not want to help regarding their UDFs :/ Why leads UDS_FLUX Example from User Guide to wrong results?
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
