November 10, 2020, 17:31 |
Velocity Adjustment
Rep Power: 7 |
I am conducting simulations on eularian granular multiphase model. Initially, my whole domain was consisting of primary phase. Later on, I add source terms via UDF and generating secondary phase from the primary phase(phase transition). I add mass momentum and energy source terms to secondary phase, whereas subtracting them from the primary phase. My question is this, are there any way to stop the velocity of the secondary phase which I generated? Meaning that, I want to keep my secondary phase motionless during its generation. In other words, I want them to stick each other, so that they can accumulate and grow without flying inside the domain. I have tried to DEFINE_ADJUST, DEFINE_EXECUTE_AT_END macros, and add second momentum sink term (first one was while generating the phase), but they did not work. I am also giving my UDF in below. Thank you very much! DEFINE_ADJUST(stop_secondary, domain) { cell_t cell; Domain *primary_domain = DOMAIN_SUB_DOMAIN(domain,1); Domain *secondary_domain = DOMAIN_SUB_DOMAIN(domain,0); Thread *secondary_th = Lookup_Thread(secondary_domain, 6); Thread *primary_th = Lookup_Thread(primary_domain, 6); real volume_fraction_secondary; thread_loop_c(secondary_th, secondary_domain) { begin_c_loop(cell, secondary_th) { volume_fraction_secondary = C_VOF(cell, secondary_th); if(volume_fraction_secondary > 0.) { C_U(cell, secondary_th) = 0.; C_V(cell, secondary_th) = 0.; } } end_c_loop(cell,secondary_th) } } DEFINE_EXECUTE_AT_END(execute_at_end) { cell_t cell; Domain *secondary_domain = Get_Domain(3); Domain *primary_domain = Get_Domain(2); Thread *secondary_th = Lookup_Thread(secondary_domain, 6); Thread *primary_th = Lookup_Thread(primary_domain, 6); real volume_fraction_secondary; thread_loop_c(secondary_th,secondary_domain) { begin_c_loop(cell, secondary_th) { volume_fraction_secondary = C_VOF(cell, secondary_th); if(volume_fraction_secondary > 0.) { C_U(cell, secondary_th) = 0.; C_V(cell, secondary_th) = 0.; } } end_c_loop(cell,secondary_th) } } |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 12:48 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 07:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
